giftiger_wunsch
I think my problem was that I assumed that the only molex socket they have on their site matched the only molex header plug they have on their site. I compared the the dimensions to the other header, and found it had exactly the same pitch and pin cross section. I just double-checked the data sheets and confirmed that.
But it appears I was wrong about the socket matching the plug. It appears they don't actually sell a match for either the plug or the socket, which is quite infuriating.
Though I don't see how their data sheet could be accurate - according to the data sheet for the sockets, they mate with 0.04mm pins, but since they were too large for 0.64mm pins...
It also means I just wasted my money on 7 34-pin headers, 2 5-pin headers, 50 2-way housings, and 100pk of molex crimp terminals.
It doesn't much help either, that the molex housings would be too large to be used with a larger header. The housing would interfere with adjacent pins. I discovered, slightly ironically, that the molex housings are a perfect fit for the 10-pin header on the robotic's arm small circuit board, and the motor cables have similar housings (except more compact and in my opinion, better. They are the basic rectangular variety in black plastic.)
Looks like I'll have to hunt for more header plugs and sockets. It appears I'll need 2-way (or better, single-pin) wire-mounted sockets which match a 2.54mm pitch, 0.64mm² pin, and a double-row 10-pin header with 2.54mm pitch and 0.05mm²? pins.
