Audio Mixer advice
I want to make an audio mixer, 2 mono inputs, 1 mono output. Is an op amp the best IC to use for a mixer, or are there ASICs out there that are better?
I'm thinking about using circuit 2 from the website below:
Simple Mixer Schematics
I've never used audio op amps before - do I need to pay attention to different selection criteria than general purpose op amps? I don't need a lot of power, since these are going to headphones and a recording device - do I need to be careful about the output impedance?
Thanks!
An opamp is the right part for the job, if you wanted to use an ASIC it would be a called an opamp.
Try the Texas TL072 or TL082, these are double opamps, and should be fine.
You need more power to feed headphones, the opamp won't do - but it's fine to feed the recording device.
