at89s8252
thendo
hi!
it's me again, this time i was wondering if i am able to connect a Switch(input) and a base a a transistor for selecting 7-segment display(output) all these in one pin of the AT89S8252 port1.
how will these work?
your response is highly appreciated!
kinjalgp
Active Member
Can you re-frame your question? I am not able to udersatnd what you are asking.
thendo
Me again!
i'm asking if it's possible to use a pin as an input and output at the same time. my input is a switch and my output is a base of a transistor(To select one of the 7-segment displays).
1-PIN = 1 SWITCH + 1 TRANSISTOR.
how will it work?
ivancho
It might depend on what type of transistor you use and what state the pin is when the switch is close..... It might work as long as you make sure that the switch doesn't trigger the transistor.
Ivancho
kinjalgp
Active Member
Yes it is possible through multiplexing. See this schematic and code. It just does what you are looking for :
