#1 & 2
I had to think back. I had the CSD option which would allow me to use the phone to dial a modem/fax/PPP machine without hanging up. I had the pre OSX Mac and the modem scripts were messed up, so I fixed them on the MAC. So, I either fixed them or modified the internal settings to work with the RAZR. It was too long ago. This was PPP before DSL ever existed. I had free PPP trough work. See
https://rickysays.com/cell-phone-as-a-laptop-modem for OSX.
When I had my first cellular plan I had unlimited data and I THINK the people that bought it changed the plan so using the tethering option was a separate cost option. When I upgraded my phone to a smart phone, the unlimited went away. There was a Windoze app provided by the carrier that allowed the phone to use the 3G data network. It would not work or it did until the carrier separated the tethered and phone data. I bought another app that allowed you to change the APN, so when the APN was the phones APN it allowed it to think that it was using the phones unlimited data.
So, in one case I modified the modem script on the MAC computer to support the RAZR and in the other, I just modified the APN settings in the computer APP. One used PPP and the other the Edge/3G network. The RAZR natively supports a modem chip set. ie. AT commands through USB and Bluetooth. The Cellular extensions is a nightmare to wade through.
Later I migrated to an Android phone and used an app called PDANET whiche requires an APP ont he PC and an APP on Android with Androide set to USB debug mode. It's a one-time pay app. It uses. my 2 GB of data per month that I pay extra for.
So, the RAZR supported a modem direct through the USB port and you needed applications to access the photos etc. Android basically can treat the USB device as a USB hard drive and through debug mode other options are made available.
Now, I'm using Linux and I have an Clear device that acts as an 802.xx AP. I can purchase plans for hours, days, weeks or a month at a time, so it's a back-up device.
With Windows, i would have a backup device and a limited 2 GB/month
There was one glitch with the Android device and tethering with PDANET. The phone gave out because USB charing would not keep up, The Android phone was made by Motorola (Backflip) and the RAZR and I think the backflip required special cables with data pull-ups to enable the fast charging;
I did try a USB Isolator with again no luck. I now have a plug-in USB monitor that will measure current/power etc. So, for using it in the car for a long time won't work.
The RAZR based on the engineering manual had three charging rates. The RAZR needs a keyboard which I have somewhere. The Backflip is so obsolete, it runs like android 2.6. It can't play videos. I do have an external device that will back up a SIM card to itself.
The Clear device does work well by the window, so sometimes I ave to use a 20' USB extension.
ASIDE: I have been planning a wireless AC upgrade with repeater for some time. The wireless ac card I have won;t work in the Linux version I have without recompiling the Kernal. The new routers have not been installed and I don;t have easy access to a wired Ethernet connection. The Laptop doesn't have a GB Ethernet connection. Believe it or not, I am using an ancient Snow Airport with a bad internal; b card, but with an external g access point. I have 3 repeaters, but I used to have 2. The 3rd repeater is one of the planned upgrade routers and it will repeat the b/g as n but at g speeds. I might be able to use a USB stick as a Clear backup on the new modems, but won't be able to reposition the antenna easily. Well, maybe if I used an active extension, but it would be at the basement level. The Apple router natively allowed wireless b under PPP. In theory, I would have had the PPP free connecton until discontinued. At one point, I set up a "man in the middle" "attack" so could access a highly restricted server from outside. I did have legitimate access to this server from home, but it was cumbersome. I had to VPN and login to the public server and then ssh into the restricted server. To get a file,I would have to transfer it to the public server (scp) and then from the public server to home (scp). I used cygwin running on a PC at work. It was still secure because you needed VPN access to work AND the MAC address of the outside PC had to be registered. Access was limited to two subnets via ssh and one subnet using SAMBA. SAMBA would not pass through any other router. The other subnet was the public access machine. VPN came in on a totally separate subnet,
