Okay, here goes...
With no signal supplied via RF or Scart:
LOPT pulses every few seconds, causing screen disturbance. Sticker near EHT lead shows potential change with each pulse by flicking toward lead and back. Potential present on chassis reading 100-120VAC on meter to mains earth. Gives nasty shock if any metal parts of chassis touched, like RF socket. Metal parts can be connected to mains earth, but LOPT still pulses.
At switch-off, crackling all around tube and the case around it, along with 15 - 20 seconds of arcing at 4-pin connector on mains-in board, between pins 2 and 3:
Pin 2 - Live from the chassis to switch.
Pin 3 - Live from mains board (hence from mains plug) to switch.
Mains earth lead held near metal parts of chassis will draw arcing to the lead instead and arcing at connector reduces, stopping almost completely if earth lead touches chassis.
EHT at anode cap dissipates very quickly after switch-off. Once arcing is over, no potential remains at anode cap.
With signal from RF or Scart:
Same symptoms, but LOPT does not pulse. Excellent picture. Geometry perfect. Just don't touch the RF socket at back or phono sockets at front, unless you like juice. No good with kids around, so will not put up with fault. Hefty shock even on carpet with rubber-soled shoes on, and it will jump, but only at switch-off.
Any more concise than that and important details will be left out.
