Ok so I have this project where I have to rotate a circular medicine compartment(the image below looks somewhat like it,the same shape),I'm currently using a 9v DC motor,I drilled a hole through the center of the compartment and attatched it to the motor shaft.
One major problem was that when I started the motor,the compartment wouldn't turn at all,I tried using gears as well but it didn't work.
So is there a stronger DC motor than 9v that could perhaps turn the compartment?I need it to be around the same size as a normal 9V dc motor so that it fits into my casing.
Here's the image link as stated above :
Note:I'm using a PLC to interface to my motor.
Thanks for the help! =)
