Until last weekend i have been thinking about controlling single phase , permenant split capacitor based motors speed control for some projects. This motors are both a fan and a compressor. Although searching lots of times , i still have questions of unanswared or need to check from experts.
At the many forum pages , everyone was asking this question for fan application. As everyone described , for below 2000W of fan applications , dimmers are good choice. They are acting neary lineer (depending on load which is airflow) at speed control using dimmer as a voltage source but if the topic is compressor things are getting changes. As you know when compressor speed control done via dimmer , compressor rotor cannot spin at low voltage using dimmer because of the low torque value. At this situation , it has to be handled by V/F constant control method for constant torque value at low voltages and low frequeny especialy for soft start operation. Since the compressor require permenant split capacitor for auxilary winding , i have some worries about changing frequency value of it.
As you know , at low frequency , capacitor will blockade the current flowing thurough to aux.winding and will do vice verse when frequency increase to nominal frequency value which is 50Hz in my location. Such i was thinking to increase motor power with increase its frequency (2kW@50Hz but 2.2kW@60Hz) for some cost saving application. The drive will be an single phase unipolar inverter for such purpose. Drive will control V/F value at constant when speed of rotor needs to be change.
Changing frequency of PSC motor is critical , must not exceed the frequency limit before capacitive reactans get too low. This will cause excessive current flow to aux.winding. So when increasing its frequency 20-50Hz to someting 70Hz , how do i know if aux winding is ok or not ? Are my thoughs are ok or do you have any idea for this ? I really need some advice before dive into it .
Thank you.
Thank you.
