amplifier
tshAL
hello friends
i want to use a summing amplifier so i googled then i found this (MC1458)
https://mediastudy.buffalo.edu/Roboti...heets/2172.pdf
what i want to get from this amplifier is (0.5 and -0.5) as outputs with inputs of (logic 0 or logic 1) so how can i connect this amplifier ?
then the outputs (0.5 or -0.5) will be an input to another amplifier with a gain of 38 ?how can i build the second amplifier?
sorry if my questions seem stupid and that because of self study of the electronics
thanks in advance
MikeMl
Most Helpful Member
Bad link. However, If the first amp outputs +/-0.5V, and the second has a gain of 38, then the output of the second would have swing from -19V to +19V, which means it needs supplies of + and - 22V or so. You need a "high voltage" opamp; one which can run on >44V between Vcc and Vee.
Roff
hello friends
thanks in advance
What is your circuit to be used for?
