74ls90/74ls47 foosball scoring--help needed
Torben
Hi all,
Short version: can you display a count from 0-4 on a 7seg led display using a 74ls90 and a 74ls47, and detect the carry when it cycles back to 0?
Long version:
My name is Torben and this is my first post. I am a computer programmer by day and a budding electronics hobbyist by night. I got the notion to build an automatic scoring system for my foosball table. This is my first digital circuit after a few analog AF projects (opamp guitar amp, bat detector, etc).
Looking through my junk box, I found a 74ls90 counter and a 74ls47 bcd led decoder/driver. Seems perfect. I made a simple debouncer with a 555, which also allows me to set the retrigger time with the timing cap on the 555. With a 7seg display, it counts from 0-9 nicely.
Unfortunately, foosball is scored best of 9, meaning that the first to 5 wins. So I need a counter which starts from 0, increments through 4, and when going to 5 signals the win (and resets the system but I'll deal with that next).
I have tried various setups on the 74ls90, and I can get it to count by 2, by 1 from 0 to 9, to count from 0 to 1, etc. But I cannot seem to figure out the way to make it increment from 0 to 5 (4 is fine if I can detect the carry to signal the win when it goes over to 5).
So the basic question is: am I misunderstanding this chip? I have read a couple of different data sheets but haven't made it yet. I don't need the full setup drawn out for me (I would like to work it out) but a hint as to what I may be missing would be great. i.e. will the idea even work or should I seek out a different part? And if possible, any pointers to reading material which would help would be great (I'm trying to work through the Art of Electronics bit on counters, but it's a little thin--or I'm a little thick). Thanks!
Torben
I hate to reply to my own first post...but by screwing around with the truth table in the datasheet, I have just discovered that I can count 0-4 on the 74ls90 by setting it up as a bcd counter and tying pins 8 and 12 to the master resets 0 and 1 respectively. I suspect that this is something that is likely to be pretty important when working with these things. :)
Anyway, I've learned enough to get this far largely by lurking here, so thanks for providing this site.
Torben
If you set the counter to divide by 10 and then reset to 0 on the 5th clock pluse it will probably do what you want. Connect pin 1 to 12, feed the clock to pin 14. Connect pins 6 and 7 to ground. Connect pin 8 to pin 3, and pin 12 to pin 2.
Win pins 2 and 3 are high the counter is reset to 0. When pins 6 and 7 are high the counter is reset to 9.
