7 Segment Led Clock using PC signal
vito3693
Hi, I'm trying to build a clock using 4 7 segment LEDs. The requirement is that the clock must display the time using signals from a computer. Currently I have a four 7 segment displays, a 555 timer, 74LS47 Binary to decimal decoder, RS Flip Flops, and a 74LS245 Buffer/Transceiver, a few resistors and capacitors. A description would be appreciated, but if possible could anyone post up a circuit diagram. Any help would be greatly appreciated. THX.
all you need are few resistors and four 7 segment displays then interface your circuit on PC parallel port, create a software to read time on your PC and send data to parallel port, VB is the easiest to use.
Well I know the basics of it and how to put it together, so thats not the problem. Its just that I'm not sure which order everything is to be placed in. Although I think it should be PC->Buffer->FlipFlops->Decoder->Display. If anyone could put up a schematic diagram it would be great. thx
You guys should rename this site "We Do Your Homework For You!", then charge $50 a pop to engineer schematics for people.
