7 band equalizer
striker_24
Anyone can help me make that 10 band equalizer to 7 band equalizer?
What are the things i will remove?
Also,can anyone give me the corresponding values of the resistors in that equalizer?
Thanks lot!
striker_24
you'll have to recompute for the bands...also your circuit seems to be so complicated, using too many op-amps...to have a better output just cascade a high pass and low pass filter and you'll adjust them to your prescribed frequency...just remember that your 5th band should attain a 1kHz frequency...
Like I said on the other website, you need simple Multiple-Feedback-Bandpass filters, not a highpass filter followed by a lowpass filter, millions of buffer opamps and two opamps without any negative feedback.
I will be using an NE5532 for the op amps with single supply, will it work if I will ground the -Vcc or do I need to follow your sticky?
opamps-gif.16569
