6 digit odometer or event counter
I need to know if anyone has built or knows how to build an odometer (with memory) for a car using a 6 digit LED common anode display based on a PIC. I've looked for some examples and I don't have a very good understanding of ASM code to program a PIC or even a modify a similar circuit to do what I want. I've looked through Nigel's tutorials but there must be something basic about programming I just don't know. I have a 16F628 and a few circuits based on the chip I was hoping to be able to modify but I'll be honest...I don't have clue!
I'm building a digital dash for one of my old cars and already have designed fuel, battery, oil pressure, and water temperature around lm3914's and ICL7107's. I can get a signal from the Vehicle speed sensor which outputs 8,000 pulses per mile. I could build it using older CMOS or TTL circuitry but that would be an overly large circuit.
I want to stress I don't mean to ask anyone do to it for me, just for help or guidance as I'm not getting the gist of it.
Thanks everyone!
You can also get compilers that will allow you to program in C or Basic. They might be an easier to learn.
I recommend using a microprocessor that has a Basic language available as I believe it's the easiest for beginners to learn (that's the reason is was invented). C or Assembly are rather arcane, somewhat like learning a completely different foreign language, whereas Basic uses standard English words for the most part.
Here's a short tutorial on Basic that may be of help to get a feel for the language. A Google search will turn up others.
Do they have a compiler that turns basic into hex for programming a PIC?
No, but here are some references for that. Also check on the Microchip website.
Here's something I found interesting. This is basically what I need less the 2 most significant digits. All I would need to do is write code to advance the count 1 digit every 800 pulses to indicate 0.1 miles or 1 digit for every 8000 pulse for 1 mile. Any suggestions?
What I really found interesting was the way the displays are multiplexed...
Here's the code:
; 8DGTCACC.INC: 8 digits CA or CC 7-segments LED display
; using conditional assembly
;-------------------- keywords for conditional assembly -----------------
; uncomment only one among these two directives
#define useCAdisplay		; if using Common Anode 7-segment display
;#define useCCdisplay		; if using Common Cathode 7-segment display
; uncomment only one among these five directives
;#define PORTX	5		; if using PORTA (full 8 bits, example: PIC16F628)
#define PORTX	6		; if using PORTB (any 18 pins mid-range PICmicro)
;#define PORTX	7		; if using PORTC (any 28 pins mid-range PICmicro)
;#define PORTX	8		; if using PORTD (any 40 pins mid-range PICmicro)
;#define PORTX	9		; if using PORTE (any 40 pins mid-range PICmicro)
; declare in the main file:
;	numdgt			; .128, then .64, .32, .16, .8, .4, .2, .1
;	rlfcnt			; .8, then .7, .6, .5, .4, .3, .2, .1
;	affvis			; ratio display visible
;	dgtvis			; digit currently displayed
;	dgtDS7			; digit #7 (left most digit)
;	dgtDS6			; digit #6
;	dgtDS5			; digit #5
;	dgtDS4			; digit #4
;	dgtDS3			; digit #3
;	dgtDS2			; digit #2
;	dgtDS1			; digit #1
;	dgtDS0			; digit #0 (right most digit)
; macro to prepare input parameters to "Disp" routine
DISPDGT	macro	posdgt, dgt
	MOVLW	posdgt
	MOVWF	rlfcnt
	MOVF	dgt, w
	CALL	Disp
	endm
;config. RBx & CC as outputs, (if Common Cathode), then RBx=HIGH & CC=LOW
;Config. RBx & CA as outputs, (if Common Anode), then RBx=LOW & CA=HIGH
SEGx	macro REGx, RBx, jump, configRB, dgtX
	BTFSC dgtX, RBx
	GOTO  jump
#ifdef	useCCdisplay
	BTFSS REGx, RBx		; conditional assembly
#endif
#ifdef	useCAdisplay
	BTFSC REGx, RBx		; conditional assembly
#endif
	GOTO  jump
	BSF STATUS, RP0		; flip to bank1
	MOVLW configRB
	XORWF dgtX, w
	MOVWF PORTX
	BCF STATUS, RP0		; go back to bank0
	MOVLW configRB
#ifdef	useCCdisplay
	XORLW 0FFh		; complement W (conditional assembly)
#endif
	MOVWF PORTX
	MOVLW	.128		; internal delay = 0.5 ms (quartz 4 MHz)
	ADDLW	0FFh		; W--
	BTFSS	STATUS, Z	; bit Z=1 (i.e. W = 0 ?)
	GOTO	$-2		; loop = 4 * 128 = 512 us
	endm
; Routine to display 8 digits
; (one digit at a time, segment by segment individually)
Display
	MOVLW	.15
	MOVWF	affvis
dispdgts
	DISPDGT	.8, dgtDS7
	DISPDGT	.7, dgtDS6
	DISPDGT	.6, dgtDS5
	DISPDGT	.5, dgtDS4
	DISPDGT	.4, dgtDS3
	DISPDGT	.3, dgtDS2
	DISPDGT	.2, dgtDS1
	DISPDGT	.1, dgtDS0
	DECFSZ	affvis, f
	GOTO	dispdgts
	RETURN
; Common Cathode digit, light segment by segment
; Common Anode digit, light segment by segment
Disp
	MOVWF   dgtvis
	MOVLW	high Tab7seg
	MOVWF	PCLATH
	MOVF	dgtvis, w	; (dgtvis) -> W
	CALL	Tab7seg		; convert
	MOVWF	dgtvis		; (dgtvis) converted to 7 segments code
#ifdef	useCAdisplay
	COMF	dgtvis, f	; conditional assembly (for Common Anode)
#endif
	CLRF	numdgt
	BSF	dgtvis, 7
	BSF	STATUS, C
rlfloop
	RLF	numdgt, f
	RLF	dgtvis, f
	BTFSC	STATUS, C
	GOTO	setBit0
	BCF	dgtvis, 0
	GOTO	rlfnext
setBit0
	BSF	dgtvis, 0
rlfnext
	BCF	STATUS, C
	DECFSZ	rlfcnt, f
	GOTO	rlfloop
DispsegA SEGx dgtvis,0,DispsegB,0FEh, numdgt ; Disp. dgtvis, bit0
DispsegB SEGx dgtvis,1,DispsegC,0FDh, numdgt ; Disp. dgtvis, bit1
DispsegC SEGx dgtvis,2,DispsegD,0FBh, numdgt ; Disp. dgtvis, bit2
DispsegD SEGx dgtvis,3,DispsegE,0F7h, numdgt ; Disp. dgtvis, bit3
DispsegE SEGx dgtvis,4,DispsegF,0EFh, numdgt ; Disp. dgtvis, bit4
DispsegF SEGx dgtvis,5,DispsegG,0DFh, numdgt ; Disp. dgtvis, bit5
DispsegG SEGx dgtvis,6,DispsegX,0BFh, numdgt ; Disp. dgtvis, bit6
DispsegX SEGx dgtvis,7,Dispoff, 07Fh, numdgt ; Disp. dgtvis, bit7
Dispoff
	CLRF	PORTX		; clear portX
	RETURN
; 8DGTCNT.ASM: main file to test display file "8DGTCACC.INC"
	list P = 16F628A
#include <p16f628a.inc>
	__CONFIG _CP_OFF &_BODEN_OFF &_PWRTE_ON &_WDT_OFF &_LVP_OFF &_MCLRE_OFF &_INTRC_OSC_NOCLKOUT
;---------------------- DEFINE HARDWARE ---------------------------------------
#define	BTN	PORTA, 4	; push button connected to RA4
;--------------------- DEFINE VARIABLES ---------------------------------------
	CBLOCK	0x70		; common RAM [16 bytes, 0x70 to 0x7F]
	numdgt			; .128, puis .64, .32, .16, .8, .4, .2, .1
	rlfcnt			; .8, puis .7, .6, .5, .4, .3, .2, .1
	dgtDS6, dgtDS5, dgtDS4	; digit #6, digit #5, digit #4
	dgtDS3, dgtDS2, dgtDS1	; digit #3, digit #2, digit #1
	ENDC
; increment one digit from 0 to maxi-1 ; if maxi, then wrap to 0
INC1	macro	digitX, maxi, jump
	INCF	digitX, f	; increment digitX
	MOVLW	maxi
	XORWF	digitX, w
	BTFSS	STATUS, Z	; digitX = maxi ?
	GOTO	jump		; no
	CLRF	digitX		; yes, then clear digitX
	endm
	ORG  0x00		; reset vector
	GOTO Start
; L.U.T. to convert a decimal value into the corresponding 7 segment code
Tab7seg
	ADDWF PCL, f		; display 7 segments GFEDCBA
	DT 3Fh, 06h, 5Bh, 4Fh, 66h, 6Dh, 7Dh, 07h, 7Fh, 6Fh
#include "8DGTCACC.INC"
Start
	bsf	STATUS, RP0	; flip to Bank 1
	bsf	BTN		; config. BTN as input
	bcf	STATUS, RP0	; back to Bank 0
	clrf	dgtDS7
	clrf	dgtDS6
	clrf	dgtDS5
	clrf	dgtDS4
	clrf	dgtDS3
	clrf	dgtDS2
	clrf	dgtDS1
	clrf	dgtDS0
tstBtn
	btfsc	BTN		; BTN pushed
	goto	majDisp		; no
IncDgts
	INC1	dgtDS0, .10, majDisp
	INC1	dgtDS1, .10, majDisp
	INC1	dgtDS2, .10, majDisp
	INC1	dgtDS3, .10, majDisp
	INC1	dgtDS4, .10, majDisp
	INC1	dgtDS5, .10, majDisp
	INC1	dgtDS6, .10, majDisp
	INC1	dgtDS7, .10, majDisp
majDisp
	CALL    Display
	GOTO	tstBtn
	END
Here's where I found the circuit:
I'm going to espouse the draconian: Take the time to do it in assembler! A Freescale microcontroller easily tracks voltage, velocity, odometer (a sub of velo), oil temp, water temp and oil pressure. I know this because I have one I built for my K75KS. Its' first build was a Z80, but they were OTP (one time pgmable). I was turned onto Freescale, by a colleague, and its' flash aspects were worth the trade off of a less flexible instruction set.
I built a second version for my K75RS: different display, & user interface, but same core.
Your first build will be tough. I can help. but neither turnkey nor free (exc tidbits). That you derive this (ostensibly) by yourself, your grasp & ability will have made significant progress.
I would be happy to generate a descriptive schema of the programs' flow, but my time is well demanded, and I'm known for teaching how to fish.... Not providing them. <<<)))
P.S Only if you want to drink the "koolaid".... I'm Old School and don't trust many of the currently accepted methods. Season to taste...
You're going to expose what? LOL! Are you quoting something esoteric?
Wouldn't a microcontroller by any manufacturer do it easily?
Sweet. You would know exactly what I'm looking for.
Can I see a photo of either version? I love instrumentation.
I agree. Only through suffering will I learn anything. That's how I learned most of what I already know. I guess my next step is to try to recode the circuit in my previous post and ask for help if I get stuck.
Actually I would like to learn how to make the koolaid. There's many flavors I would like to be able to make. I have the ingredients, I just need to figure how much to use and when to use them. Unfortunately I don't know enough about chemistry.
My eyes tend to glaze over whenever I see an Assembly program, but if you want to go through the time consuming pain of learning it, that's your call. But unless you need to program for absolute maximum efficiency in the program execution, Assembly has no particular advantage. And it can take a dozen or more Assembly commands to do what one high level language command can do.
I guess Assembly is just too tedious for me, sorta like trying to write a large number in binary rather than decimal. :rolleyes:
Here's a 12 digit timer,
[MODNOTE]Deleted link[/MODNOTE]
There's also seems to be some info about the 16F628, programming, and assembly commands and I'm starting to make sense of things.
