555 Sinking Current - How?
All the examples Ive found for 555's show how to source current (turn on an LED, etc). How can I get it to sink current? Ideally, my circuit is going to sink an unknown amount of mA (shouldnt be very high, but 555's are cheap anyways), from 5v (signal is pulled to 5v inside PCM) down to GND @ 57Hz, running off 12v. If someone would toss this together real quick, that would be nice ;) But just telling me how to sink current would work just as well.
EDIT and ha ha to everyone who says "this sounds like homework". Im using it to emulate a Flex-Fuel sensor on an '00 Ford Ranger:
The fuel sensor signal is a square-wave voltage signal. The signal varies in both frequency and pulse width:
The frequency of the signal indicates the ethanol percentage. The output frequency is linear with respect to the percentage of ethanol content in the fuel. The PCM provides an internal pull-up to five volts on the signal circuit, and the fuel sensor pulls the 5 volts to ground in pulses. The normal range of operating frequency is between 50 and 150 Hertz:
50 Hertz indicates 0% ethanol
150 Hertz indicates 100% ethanol
It will source current if you connect the load to the low rail and it will sink current if you connect the load to the high rail (then the load is ON when the output is low).
Basically, make the flasher ground through the 555 timer (lookie at the picie)
Yes, as long as it is grounding through the 555 timer, it will work just fine. I generally design circuits around Source, but to make simple flashers just have 1 LED sink and source, making it alternate as the square wave rises (5V) and grounds (GND).
Note: 555 timers can sink and source 200mA.
Since the sensor wire is pulled to +5v by the PCM, I should be using an LM317T to drop the supply voltage of 12v to 6.7v, since Output = VCC - 1.7v, right?
Actually now that I think about it, would it be better for me to just supply the IC off 12v and use a transistor connected to the output of the 555 to pull the signal wire to ground?
The output of a 555 does not go to ground. With a load of 200mA its output low voltage could be as high as 2.5V to 3V. with a low sinking current then the output voltage goes close to ground. See the graph on its datasheet.
I wasnt running 200ma off it, only about 20.
With a 10mA load, a 555 can sink to typically 0.1V or 0.25V max.
with a 50mA load, it can sink to typically 0.4V or 0.75V max.
With a 100mA load, it can sink to typically 2.0V or 2.5V max.
With a 200mA load, it can sink typically to 2.5V but there is no max.
It can source current up to 200mA but the voltage drops are a little higher than when it sinks current to a load.
A transistor with a base current that is 1/10th the collector current has a much lower saturation voltage loss than a 555.
For some reason its hard for me to visualize this; Ive got the 555 circuit figured out (R1 = 4.7k, R2 = 10k, C1 = 1.0uF, f = ~58Hz), but I dont know how to hook up the transistor (NPN/PNP, base resistor value, that kind of stuff) to the sensor wire (which is pulled to 5v inside the PCM) so that it pulls the sensor wire to ground.
The base resistor for a switching transistor is calculated by using 1/10th the collector current in the bese resistor. Then the value of the base resistor is calculated by Ohm's Law (the voltage across it divided by the current in it).
Of course you should look on the datasheet for the 555 and for the transistor to determine the voltages.
ParkingLotLust said:
How do I find out the current? I dont know the value of the resistor pulling the signal line to 5v.
The base current for a switching transistor is simply 1/10th its collector current.
The collector current is determined by the load resistance and the supply voltage minus the 555 output voltage loss.
