1wire DS18B20
tresca
Is there a minimum time before you can issue a convert command ?
I have the convert command running in an endless loop and each time it displays a few of the scratchpad registers on a glcd. I notice that it works once, and only once. (i.e if i take the convert command out of the loop and just run it once and then display, it works, but if i run the command again, i get 0xff.
If needed I can post my code, but im just curious if there is min time before each command. I did check the datasheet and i couldnt see anything in there.
Mike - K8LH
All of the timing specs' are available in the Data Sheet.
Are you waiting for the conversion to complete before reading issuing the "read scratchpad" command (using a time delay or polling for the 'conversion compete' bit)?
Mike
tresca
Well like i said it works the first time, if it works the first time then it should work the next time.
void onewire_ConvertT()
  unsigned char scratchBuffer[9];
	char x=0;
 unsigned char temperature[3];
	char CRC[8];
	unsigned char  temp1,temp2,temp;
	int result;
//	temperature[2]=0b10011001;
//	if(onewire_reset())
//		write_lcd(3,0,"Device not found.");
//	else{
		onewire_reset();
		onewire_write_byte(skipRom);
		onewire_write_byte(convertT);
		delay480us();
		delay480us();
		onewire_reset();
		onewire_write_byte(readScratchpad);
		scratchBuffer[0]=onewire_read_byte();
		scratchBuffer[1]=onewire_read_byte();
		scratchBuffer[2]=onewire_read_byte();
		scratchBuffer[3]=onewire_read_byte();
		scratchBuffer[4]=onewire_read_byte();
		scratchBuffer[5]=onewire_read_byte();
		scratchBuffer[6]=onewire_read_byte();
		scratchBuffer[7]=onewire_read_byte();
		scratchBuffer[8]=onewire_read_byte();
	//	scratchBuffer[0]=0b10001010;
	//	scratchBuffer[1]= 0b00000001;
		temp1=scratchBuffer[0]>>4; //only care about 8bits(no fractions)
		temp=scratchBuffer[1]&0x07;
		temp<<=4;
		temp=temp1 | temp;
		scratchBuffer[4]=temp;
		btoa(scratchBuffer[0],temperature);
		write_lcd_data(0,0,temperature);
		//scratchBuffer[0]=(scratchBuffer[0]>>4)|((scratchBuffer[1]&0x07)<<4);
		btoa(temp,temperature);
	//	write_lcd(0,3,"Temperature:");
		write_lcd_data(0,1,temperature);
its not exactly nice right now, i just want it to work before i worry about anything else.
picasm
tresca, as Mike has said, using the default 12 bit resolution,you have to either wait over 3/4 second between convert commands (it takes that long to get a reading) or you have to keep polling it until it has finished processing each reading.
gaspode42
Conversion Time
Tresca
I just had a look at the datasheet and it does say that the max conversion time is 750 ms and I see you only have 960us. Is it an issue with the library as I know it does not work with DS1821.
Rupert
tresca
Well I modified the code to poll rather than go through a timed delay.
Still the same problem.
Looking at the registers it alternates between these two values
Temp LSB = 1010 1011
Temp LSB = 1111 1111
when temp is reading 1's across the board, I looked the rest of the scratchpad, and they are also all 1's. So it seems that the ds18B20 is not responding on occassion (i.e after a command. )
I just dont get why it works the FIRST time (every time), but as soon as I try to get the temperature, its always 1's.
tresca
Sigh. Figured it out.
When I was working on my GLCD code, i used a byte load for PORTC (which happens to be a mix of things).
Thanks for info.
tresca
Ok, I jumped the gun before. I thought I knew where it was. I dont.
I know WHAT the problem is (found a work around), but Im still in the works to figuring out exactly where the problem occurs and why.
tresca
OK NOW ! I got it.
I've read on this forum about Read-modify ports. I never really had a problem with them, and never really knew what the LAT register was truly for.
I dooooo now.
My GLCD uses some pins on PORTC as does my 1wire device. When I change CS1 and CS2 I am indirectly affecting my 1wire device.
Now it works.
Get resolution to work next and multiple devices.
I'll release my code to the public just to get an idea. I've searched and most of the code I found I had problems with and just wouldnt work. So im writing my own.
Stay tuned !
Diver300
Most Helpful Member
If you have a powerful enough pull-up you can read multiple devices at nearly the same time. You only have to wait for one lot of 750 ms
If you issue the reset, (receive presence pulse) then skip ROM and start conversion, then enable the strong pull up, all the devices will convert the temperature. You then read one at a time.
EE World Online Articles
Loading
