You should only need the .asm file. You can find some template files in the following directory:2 files that are required for the 18Fxxxx (.tmp and the .asm).
Cut and paste the error message and post it here so we'll be able to help you.After selecting the 2 file I believe are needed
the Build option fails to build.
Have you modified the file at all? Because the file I have doesn't have this statement in it.Symbol not previously defined (_WRT_ENABLE_OFF)
list p=16f88 ; list directive to define processor
#include <p16F88.inc> ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_IO
__CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See data sheet for additional information on configuration word settings.
;***** VARIABLE DEFINITIONS
w_temp EQU 0x71 ; variable used for context saving
status_temp EQU 0x72 ; variable used for context saving
pclath_temp EQU 0x73 ; variable used for context saving
ORG 0x000 ; processor reset vector
goto main ; go to beginning of program
ORG 0x004 ; interrupt vector location
movwf w_temp ; save off current W register contents
movf STATUS,w ; move STATUS register into W register
movwf status_temp ; save off contents of STATUS register
movf PCLATH,W ; move PCLATH register into W register
movwf pclath_temp ; save off contents of PCLATH register
; isr code can go here or be located as a call subroutine elsewhere
movf pclath_temp,w ; retrieve copy of PCLATH register
movwf PCLATH ; restore pre-isr PCLATH register contents
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
main
; remaining code goes here
; initialize eeprom locations
ORG 0x2100
DE 0x00, 0x01, 0x02, 0x03
END ; directive 'end of program'
swapf w_temp,f
main
ORG 0x2100
kchriste said:Have you modified the file at all? Because the file I have doesn't have this statement in it.
