16f628 problem
zhaniko93
	list      p=16F628A            ; list directive to define processor
	#include <P16F628A.inc>        ; processor specific variable definitions
	__config _CP_OFF & _LVP_OFF & _WDT_OFF & _INTOSC_OSC_NOCLKOUT
  clrw
   bsf STATUS, RP1
   movlw TRISA
    movlw TRISB
   bcf STATUS, RP1
   movlw 0xFF
  movwf PORTB
sas goto sas
	end
Can any1 tell me why doesn't it work? PORTB isn't set to 1 and TRISB and TRISA remain 0xFF (I saw it in PIC SIMULATOR IDE)
You can remove the clrw and replace the movlw TRISA and movlw TRISB with clrf TRISA and clrf TRISB
After a quick look at the datasheet, almost every pin on PORTB (except RB5) has a peripheral linked to it.
Edit: Wow what the hell, I hit enter to go to another line, not to submit the post. >_>
And why isn't PORTB set to 1 or even TRISB?
clrw
bsf STATUS, RP1
movlw TRISA
movlw TRISB
bcf STATUS, RP1
This Doesn't work! TRISB is left 0xFF after that!
  clrw
   bsf STATUS, RP1
   movlw TRISA
    movlw TRISB
   bcf STATUS, RP1
   movlw 0xFF
  movwf PORTB
sas goto sas
    end
Try this in the Sim.
You MUST turn OFF the comparators, CMCON
also you had selected BANK2 not BANK1
and its movwf not movlw...
    errorlevel  -302 , -207             ; suppress messages 302 [Bank] and 207 [label in column 1]
    org 0x0000
    movlw 007
    movwf CMCON
       bsf STATUS, RP0
    movlw 0x00
    movwf TRISA
       movwf TRISB
       bcf STATUS, RP0
       movlw 0xFF
      movwf PORTB
sas goto sas
    end
Why not use banksel TRISB and forget this bsf STATUS, RP0
You'll always be in the right bank and have more time for
BANKSEL 1 and BANKSEL 0?
and after selecting the correct bank, compiler gives warnings anyway. why?
This image is from the MPLAB help files.
EDIT:
Use this line as part of the code header.
#include <P16F628A.inc> ; processor specific variable definitions[label in column 1]
[B]errorlevel  -302 , -207             ; suppress messages 302 [Bank] and 207 [label in column 1][/B]
    movlw 007
    movwf CMCON
  BANKSEL TRISA
    movlw 0x00
    movwf TRISA
       movwf TRISB
    BANKSEL PORTA
       movlw 0xFF
      movwf PORTB
sas goto sas
end
gives bank warnings why?
and also what does goto $ or goto $+7 or $-2 etc. mean?
movlw 007
movwf CMCON
BANKSEL TRISA
movlw 0x00
movwf TRISA
movwf TRISB
BANKSEL PORTA
movlw 0xFF
movwf PORTB
sas goto sas
end
I just answered that point...
The symbol '$' is the current program counter value.
So goto $+3; means the current PC value + 3
Do you have MPLAB IDE in your PC.????
When you get error messages, post an image of the error messages.
ericgibbs
Than you very much I just understood everything (sorry for bad english :))
Where did you have errors
Debug build of project `C:\asm\asm.mcp' started.
Language tool versions: MPASMWIN.exe v5.37, mplink.exe v4.37, mplib.exe v4.37
Preprocessor symbol `__DEBUG' is defined.
Wed Dec 22 00:47:15 2010
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\asm\asm.o".
Clean: Deleted file "C:\asm\asm.err".
Clean: Deleted file "C:\asm\asm.hex".
Clean: Deleted file "C:\asm\asm.lst".
Clean: Deleted file "C:\asm\asm.cof".
Clean: Deleted file "C:\asm\asm.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628A "asm.asm" /l"asm.lst" /e"asm.err" /d__DEBUG=1
Executing: "C:\Program Files\Microchip\MPASM Suite\mplink.exe" /p16F628A "asm.o" /u_DEBUG /z__MPLAB_BUILD=1 /z__MPLAB_DEBUG=1 /o"asm.cof" /M"asm.map" /W /x
MPLINK 4.37, Linker
Copyright (c) 1998-2010 Microchip Technology Inc.
Errors : 0
Loaded C:\asm\asm.cof.
Debug build of project `C:\asm\asm.mcp' succeeded.
Wed Dec 22 00:47:16 2010
BUILD SUCCEEDED
Try this
 errorlevel  -302              ; suppress message 302 from list file
	movlw 007
	movwf CMCON
	BANKSEL TRISA
	movlw 0x00
	movwf TRISA
	movwf TRISB
	BANKSEL PORTA
	movlw 0xFF
	movwf PORTB
sas:
	goto sas
 end
You wasn't having real errors you just need to use the tab and set error level to 302
It's reminder message to tell you that a variable that is being accessed in not in bank 0.
But BANKSEL set's it right
I'm sorry I posted and look up where did all this come from LOL it wasn't showing your last 4 post
hi b80,
No problem, there are more bugs in this sites software than a Motel mattress....:rolleyes:
Regards
HELLPP!! I've benn programming my pic16f628 I hav bought just today and after programming it twice on third time i Can't any more? When I put it in **broken link removed** programmer red light used to shine but doesn't shine any more and when I click on PROGRAMM IT button, green one shines but it doesn't write actualy, because when it starts verifying, it fails and When I press read code button, it reads FFFFFFFFF... all whats wrong? When I put it on breadboard, It does what it was programmed to do (flash led) and so it isn't corrupt yes? what can I do?
P.S. When i connect it to COM port (programer), red LED shines and then goes off imediatelly and Programmer works fine (it programms other micros well)
