12vdc to 6.7vdc regualtor
frosty
looking for a good regualtor crt. for a constant 6.7vdc from a lead acid battery 12vdc to 6.7vdc It is on a metal detector. any help out there?????
Us an LM317 adjustable voltage regulator. (Formulas given in data sheet)
Thank you, so it's just a simple cit.or where can I find a diagram.
Look at this extract from the data, use the formula to calc the Vout.
Thank You, I was never good at the math, so how does the math work out to get 6.7vdc ?????? don"t understand it .
If this is for a PI detector (Minelab or other), you should use a switching regulator. Linear regulators are inefficient, and the Minelab PIs typically draw an amp or more.
No this is gp exereme minelab
The GP Extreme is a pulse induction (PI) detector. It draws about an amp when operating. If you use linear regulator, you will get about 60% of the battery life compared to a switching regulator. With a 12V battery, you will need a buck regulator.
12vdc 6.7vdc reg.
Hero999, Yes the metal detector draws .8a to 1amp.would it work for this Pules induction detector, if so I need to have an out voltage of 6.7 constant. It will be hooked up with lead acid 12vdc 7anp hr, battery. vin 12vdc, vout 6.7vdc.
The circuit won't do what you want as-is; it need a few modifications for it to do what you want.
[FONT=Arial,Helvetica,Verdana,Geneva,sans-serif][SIZE=-1]**broken link removed**
Official Home Page of Roman Black
All components as per the list on the page linked above except for:
Q1 needs to be fast, high gain (at least an Hfe of 50) and rated for 1A minimum (2A is better).
Zener is 7.5V
R2 is 820R
RZ is 3k3
L1 needs to be rated to 1.5A
[/SIZE][/FONT]
reg,
Hero999, on your parts list it shows a capacitor as CS 47uf, but its not on the drawing??? the zener z1 couldn't find it, also the L1, and the Q1???? got on the net and nothing. do you know where I can get then. Thank You.
It's just a capacitor connected across the input power supply, i.e. 12V to 0V.
