x.10 protocol
Then you need a microcontroller. There is an app note on Microchips site using the 16F877 as an X10 device with code and schematics.
designed a filter to extract 120khz data signal.....but its contain harmonics of ac...i need to attenuate that harmonics
yes.......but i dont know how an hex inverter work as tuned amplifier.........but the untuned part is ok
that tuned amplifier produce output for all frequency.......as a result of that the dc volatge at the envelope detector is fluctuating
doing this as project using this pdf u providied from the past 1 week.......all things r working in that ckt except tuned amlifier
And you built it without parts substituting, I would suggest an entry on Microchips own forums as it is a Microchip App note. I can only assume many have built it without problems else they'd change the app note.
you may take a look at the schematic at :
there is a tuned 120khz filter with simple transistors
I simulated this filter and it seems to work.
I also simulated the filter with the 4069 of microchip app note and I couldnt make it work ...
good luck
also as I'm planning to make such thing please post here if it works really !
