I would like to have 2 small fans 12v dc (out of old pc's) turn on at about 100-120 degrees F and stay running to draw the heat from the sides of the wood stove and push the hot air into the room.
what kind of snap disc should i use ?
output from the transformer ac/dc is 12 vdc and 1.2 amps 30 watts
the fans 2 of them on same transformer are 12v dc and 1.2 amps
i want the fans to turn on at 100-120F
do i just connect the snap disc in line with the fans ? before the fans i am guessing.
The fans and snap dis will be mounted on a metal sheet about 4-5 inches from the fan sides. The stove outer housing which is light sheet steel.
any help for this newb would be great..
diaghrams are good too
thanks in advance.
Scott
thanks in advance.
Scott
