    Dismiss Notice
understanding code: accelerometer with arduino
Discussion in 'Arduino' started by meowth08, Jan 14, 2013.
  1. meowth08
    meowth08 Member
    Aug 18, 2011
    241
    7
    Philippines
    Code (text):
    #define ANALOG0 14
    class Accelerometer
        int p[3]; // which analog pins
        int a[3]; // acceleration, zero-based
        int b[3]; // acceleration bias/calibration information
        int g, t, r; // cached copies of calculations
        int scale; // scaling factor between ADC and gravity
    public:
        Accelerometer(int pinX, int pinY, int pinZ, int pinVCC, int pinGND)
            pinMode(pinGND + ANALOG0, OUTPUT); digitalWrite(pinGND + ANALOG0, LOW);
            pinMode(pinVCC + ANALOG0, OUTPUT); digitalWrite(pinVCC + ANALOG0, HIGH);
            pinMode((p[0] = pinX) + ANALOG0, INPUT);
            pinMode((p[1] = pinY) + ANALOG0, INPUT);
            pinMode((p[2] = pinZ) + ANALOG0, INPUT);
            for (int i = 0; i < 3; i++)
                b[i] = 512;
            g = t = r = 0;
            scale = 100;
        void update()
                a[i] = analogRead(p[i]) - b[i];
            g = t = r = 0;
        void dump()
            Serial.print(  "x="); Serial.print(a[0]);
            Serial.print("\ty="); Serial.print(a[1]);
            Serial.print("\tz="); Serial.print(a[2]);
            Serial.print("\tmg="); Serial.print(milligee());
            Serial.print("\tpitch="); Serial.print(pitch());
            Serial.print("\troll="); Serial.print(roll());
            Serial.println();
        void calibrate()
                b[i] = analogRead(p[i]);
            b[2] -= scale;
            update();
        int milligee()
            if (g != 0) return g;
            long squared = 0.0;
                squared += (long)a[i] * (long)a[i];
            g = squared * 1000 / (scale*scale);
            return g;
        int accel(int axis)
            if (axis < 0 || axis > 3) return 0;
            return a[axis];
        int roll()
            if (r != 0) return r;
            r = (int)(atan2(a[0], a[2]) * 180. / M_PI);
            return r;
        int pitch()
            if (t != 0) return t;
            t = (int)(acos(a[1] / (float)scale) * 180. / M_PI);
            return t;
        void loop()
            update();
    I copied this code from the net.
    Kindly add some comments on what each part of the code is for.
    I am having a hard time understanding C.
    Thanks in advance.
    m8
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,145
    907
    Rochdale UK
    ONLINE
    Unfortunately this is worse... Its C++... If you don't grasp C++ ( Object Orientated ) It won't be easy to explain
    Some comments added
    Code (C):
    #define ANALOG0 14
    class Accelerometer             /// Name of the class
        // the following are class variables ( private and can't be seen outside the scope of the class)
    public:     // All these functions below WILL be seen outside of the class scope.
            pinMode((p[2] = pinZ) + ANALOG0, INPUT);     // pinmode is a library function
                b[i] = 512;
            g = t = r = 0;
            scale = 100;
        void update()   //  This can be called to refresh all the above variables.
                a[i] = analogRead(p[i]) - b[i];     // analogRead is a library function
            g = t = r = 0;
        void dump()     // this is called to print the variables
            Serial.print(  "x="); Serial.print(a[0]);       // serial is the serial class. Print is one of the functions
            Serial.println();
        void calibrate()    // Again.. Called to calibrate the accelerometer
            b[2] -= scale;
            update();
        int milligee()      // returns the G force
            long squared = 0.0;
            return g;
        int accel(int axis) // this returns the acceration as an Int
            return a[axis];
        int roll()  // this returns the roll as an Int
            return r;
        int pitch()     // this returns the pitch as an Int
            return t;
        void loop()
            update();
  3. meowth08
    meowth08 Member
    Aug 18, 2011
    241
    7
    Philippines
    Thanks for the reply.
    I think it would be hard if I start with something I don't understand.
    I'll try to post the actual problem I have later.
    But I'll try my best to make my own code.
Share This Page
