Bug in Arduino compiler.
Pommie
Most Helpful Member
I recently had a bug in my program and couldn't figure it out.
Turns out I'd typed count==25; instead of count=25;
I thought this would be an error or at least a warning. It isn't.
As an experiment I placed the following in a new sketch,
void setup(){
  uint8_t count;
  count==25;
  Serial.begin(115200);
  Serial.println(count);
void loop(){}
It compiles fine but count is displayed as 0.
Edit, is this normal compiler behaviour? Just tried it in XC8 with the same result.
I know the difference, I was expressing my surprise that it doesn't generate an error or warning.
I am not sure about this, from an ANSI C point of view, but the ==
statement does not have to be in parenthesis so compiler cannot
figure out what its supposed to be. And vice versa, if its single =
is it supposed to be test, a == ?
Maybe a C expert can comment on this.
Regards. Dana.
I just consider it a syntax error and it should be flagged as such.
I'm just wondering if there is a construct along the lines of strcpy(buff,count==25?"is 25":"isn't") that I'm not aware of.
It is not a syntax error. As written, it is syntactically correct. It is a logical expression that evaluates to TRUE or FALSE. It is semantically wrong, because a free-standing logical expression has no effect on the overall program. I do agree that a "smart" compiler could throw a warning for useless expressions masquerading as statements. A really smart compiler would just optimize it away into nothingness and maybe mention the fact that you're being wasteful by coding free standing expressions that have no effect.
It's not a syntax error, it's perfectly correct C code - so can't be flagged as a syntax error (and yes, I do it a LOT as well :D )
If you write it slightly differently though, it WILL trigger an error:
'25==count' does exactly the same, but '25=count' generates an error (because you're writing to a constant).
If you look at MCC created code, it's often done that way.
Using 25==count makes sense when used as a comparison but using an assignment backwards doesn't make sense. You are simply introducing a deliberate error!
Note, the construct I wrote, strcpy(buff,count==25?"is 25":"isn't") is valid in C.
I was wondering what use count==25 might have (if any).
I have only ever done this once. I often do if(count=25) (which I suspect you mean) but that's a completely different problem.
The problem is a line which only contains count==25; is valid in C but I've no idea why.
XC8 does the same thing if(x=5) gives a warning but x==5; doesn't!!!
Caught me out a few times too, Should be an error I guess. what about .. if(count=2) .... not sure XC8 errors ?
In that case xc8 gives a warning.
warning: using the result of an assignment as a condition without parentheses [-Wparentheses]
But not if you type (only) LATA==0; It just compiles to nothing.
It is valid BECAUSE any expression is a valid statement period FULL STOP.
This is similar to x++; which is a valid expression that can turn into a statement. This is also similar to a function call, is evaluated as an expression and returns a value. They are all syntactically the same, but semantically different.
A smart compiler that realizes that an evaluated expression has no effect is free to optimize the evaluation away without effecting the operation; it assumes you knew what you were doing, which is not always the case. If it was really benevolent it might throw a warning to draw your attention to the matter.
Yes, still doesn't help catching a typo. Most other typos I can think of result in an Error or Warning.
Think I'll look for a lint type program.
I'll be curious to learn what you find. I've never had the need to take such an action.
I'll probably wait until next time I've got a bug I can't find. However, forewarned is forearmed. As I said above, I've only done this once.
I cross my fingers in your favor and hope for the best result possible.
