Sim900 not working with Arduino
Vicky58911
Recently I bought Sim900a module and Arduino Mega 2560 to run my old code for sending sms and call, but now there is a problem as I am unable to send sms or either call, my code is attached below.
#include <SoftwareSerial.h>
SoftwareSerial gsm(2,3);
void setup()
gsm.begin(9600); // Setting the baud rate of GSM Module
Serial.begin(9600); // Setting the baud rate of Serial Monitor (Arduino)
delay(100);
void loop()
if (Serial.available()>0)
switch(Serial.read())
case 's':
Send();
break;
case 'r':
Recieve();
break;
case 'S':
Send();
break;
case 'R':
Recieve();
break;
if (gsm.available()>0)
Serial.write(gsm.read());
void Send()
Serial.print("Sending");
gsm.println("AT+CMGF=1");
delay(1000);
gsm.println("AT+CMGS=\"+xxxxxxxxxxxx\"\r"); // Replace x with mobile number
delay(1000);
gsm.println("Hello I am GSM modem!!!");// The SMS text you want to send
delay(100);
gsm.println((char)26); // ASCII code of CTRL+Z
delay(1000);
void Recieve()
Serial.print("Receiving");
gsm.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
delay(1000);
What modules did you originally use ?
Unlike the Sim 900, the 900A firmware is locked to Asian countries only; are you there ?
http://www.raviyp.com/embedded/174-difference-between-sim900-and-sim900a-gsm-modems
I am currently living in Pakistan, Asia and I bought the correct sim900a module as mentioned in your link from http://www.w11stop.com/simcom-gsm-sim-900a-module
my sim900a is working fine as this module has been used for other projects also. I think the problem lies either with my code or my arduino mega.
The code worked when i changed the software serial from(2,3) to (10,11) since Arduino Mega does not support software serial on (2,3) pins
