koolguy
Active Member
I working on serial comm from uC to PC i am using this **broken link removed** and this terminal program window 7....
here is the showing error........
Make: The target "C:\Users\Abc\Documents\mplab\UART.p1" is out of date.
Executing: "C:\Program Files (x86)\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 C:\Users\Abc\Documents\mplab\UART.c -q --chip=16F877A -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [312] C:\Users\Abc\Documents\mplab\UART.c; 32.1 ";" expected
Warning [361] C:\Users\Abc\Documents\mplab\UART.c; 36.1 function declared implicit int
Error [285] C:\Users\Abc\Documents\mplab\UART.c; 40.1 no identifier in declaration
Warning [374] C:\Users\Abc\Documents\mplab\UART.c; 40.1 missing basic type; int assumed
Error [314] C:\Users\Abc\Documents\mplab\UART.c; 40.1 ";" expected
Error [285] C:\Users\Abc\Documents\mplab\UART.c; 41.1 no identifier in declaration
Warning [374] C:\Users\Abc\Documents\mplab\UART.c; 41.1 missing basic type; int assumed
Error [314] C:\Users\Abc\Documents\mplab\UART.c; 41.1 ";" expected
********** Build failed! **********
#include <htc.h>
__CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
#define _XTAL_FREQ 20000000
#define NINE 0 /* Use 9bit communication? FALSE=8bit */
#define BAUD 9600
#define RX_PIN TRISB2
#define TX_PIN TRISB5
#define DIVIDER ((int)(_XTAL_FREQ/(16UL * BAUD) -1))
#if NINE == 1
#define NINE_BITS 0x40
#else
#define NINE_BITS 0
#endif
#if HIGH_SPEED == 1
#define SPEED 0x4
#else
#define SPEED 0
#endif
Initialize ();
void main ()
Initialize ()
while(1)
putchar('H'); //print the letter 'H'
putchar('i'); //print 'i'
putchar('\r'); // return to beginning of line
putchar('\n'); //new line
Initialize ()
RX_PIN = 1;
TX_PIN = 1;
SPBRG = DIVIDER;
RCSTA = (NINE_BITS|0x90);
TXSTA = (SPEED|NINE_BITS|0x20);
