    Dismiss Notice
Regulated lab power supply with variac?
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by nzoomed, Aug 13, 2017.
  1. nzoomed
    nzoomed Member
    May 15, 2007
    82
    2
    Tauranga
    Im wanting to build a lab power supply using a variac to control the voltage going into a stepdown transformer to give me the option of variable AC voltage in addition to DC fed through a rectifier.
    I will probably have 50V on the secondary or something near enough from the UPS transformers i have floating around.
    I dont know if this is the most practical means of building a lab power supply, but I dont really want to go down the path of using an LM317 which dissipates alot of heat.
    I would want to also add current regulation, so dont know how you would go about doing this by means of a variac.
    Am I better using a switching regulator? I like the idea of building a variable voltage power supply and a variac makes it easy for AC power especially.
    If i want lets say 0-50V and current limiting, with the ability to change between AC and DC, whats the best option?
    TIA
  2. Reloadron
    Reloadron Well-Known Member Most Helpful Member
    Dec 23, 2009
    6,774
    281
    Cleveland, Ohio USA
    I have worked with several older Variac (auto transformer) type power supplies which were 200 VDC 100 ADC units. The downside to what you are describing is lack of regulation. While I would not discourage building a bench power supply I can buy assorted 0 to 30 and 0 to 50 VDC units providing 3.0 to as high as 10.0 amps in the $50 to $60 USD range. I doubt I could build one that inexpensive. Really depends on what your output specifications are?
    Ron
    • Agree Agree x 1
  3. schmitt trigger
    schmitt trigger Active Member
    May 24, 2009
    883
    84
    In the late 1970s, I saw a high power regulated AC supply which utilized servo motors which would drive, via gears, the Variacs.
    Even then, it was old technology. The size of a medium household fridge, weighted close to 700 kilograms.
    Also, it was slow responding.
    Like S-l-o-w.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Reloadron
    Dec 23, 2009
    6,774
    281
    Cleveland, Ohio USA
    Schmitt Trigger:
    Yep, worked with plenty of those. Talk about a brute power supply, those were brutes. When I was retiring I left suggestions for replacements. Motor driven variacs all geared and with limit switches at the extremes. You used a crane to plant them and they didn't move. Exactly, they looked like refrigerators, large refrigerators at that. :) They were late 1960s design and in their defense worked fine for decades and it was impossible to overload those beast.
    Ron
  6. nzoomed
    nzoomed Member
    May 15, 2007
    82
    2
    Tauranga
    Yes lack of regulation is the main drawback.
    As you say, its cheap to buy them pre assembled.
    My friend is buying modules from china off ebay with pre-programmed voltages at the push of a button to build his supply.
    Dunno what the quality of this sort of stuff is like from china, but the VARIAC may just be best for AC voltages only and i use a seperate regulated unit for the DC supply.
  7. Reloadron
    Dec 23, 2009
    6,774
    281
    Cleveland, Ohio USA
    That is how I would go about it using a variac for a variable AC supply and then build a regulated DC supply but all things considered, I would buy over build a DC bench supply.
    Ron
  8. ronsimpson
    ronsimpson Well-Known Member Most Helpful Member
    Apr 17, 2007
    7,247
    961
    Loveland, CO USA
  9. schmitt trigger
    May 24, 2009
    883
    84
    Ron;
    at the time, Superior Electric "Powerstats" variacs were the "Rolls-Royce" in the industry.
    Built, literally, like tanks. Would last forever.
  10. ronsimpson
    Apr 17, 2007
    7,247
    961
    Loveland, CO USA
    In about 1970-something I used one of these and a motor, on a 10,000 watt transmitter. (grid power supply) When the output power is over +102.5% the motor turned down the voltage. When the power is under 95% the motor turned the knob up.
    Not my finest design, but it did work for decades.
  11. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    11,041
    541
    AZ 86334
    I still have a 10A 0V to 30V variable linear supply with a Variac ahead of the main transformer. The voltage drop across the pass transistors is metered, so the Variac can be set so that the unregulated voltage upstream of the regulator is just above the drop-out voltage to minimize dissipation in the regulator at any preset output voltage...
    I built it in the 1970s...
  12. ronsimpson
    Apr 17, 2007
    7,247
    961
    Loveland, CO USA
    I used a switch to jump the diodes up/down through taps on the transformer. (High/M/Low) This kept the transistors at a good temperature.
  13. Reloadron
    Dec 23, 2009
    6,774
    281
    Cleveland, Ohio USA
    Yeah, located up the road here in Cleveland, Ohio. Superiour also made some of the brute supplies we mentioned earlier. Think I have a few of their variacs laying around here somewhere. :)
    Ron
  14. tomizett
    tomizett Active Member
    Aug 11, 2013
    414
    45
    UK
    nzoomed:
    Mikes post here:
    is exactly what I envisaged when I read your initial post. It's not the most practical project in this day-and-age, but if you have the parts and want to use them this would be a fascintaing project.
    It's essentially an extension of the technique Ron mentions above for switching taps - which is still used in plenty of modern bench power supplies.
    As long as your output transistors can take the full output voltage, you can still have good regulation and full current limiting.
    Myself, I have an isolated variac unit to which I can couple a rectifier set with adjustible overcurrent cutoff (with steep foldback). I find it very useful for working on higher-voltage stuff like off-line switchers and, in centre-tapped mode, high power amplifier modules.
  15. atferrari
    atferrari Well-Known Member
    Oct 8, 2003
    2,810
    121
    Buenos Aires - Argentina
    ONLINE
    And surely bulky. Maybe the AC availability justifies that?
Share This Page
