Oshonsoft users?
hi Jim,
This should do it, unzip the attached zip.
Read the notes at the top of the Basic Program listing.
  • jim2zip.zip
just uploaded that all to my real life PIC and it is only displaying the top line as a solid block and that is it...
the sample runs fine along with a few other things in real life so the hardware is just fine; and the assembler runs well in OS... but in real life we have this problem... wouldn't be much of a problem if i didnt have just 36 hours... at least i got the winter olympics to keep me company while i work on this...
i believe the problem is in here:
T1CON.T1OSCEN = 1
T1CON.TMR1CS = 0
T1CON.TMR1ON = 1
T1CON.T1CKPS0 = 1 'tmr1 prescaler /256 gives a 2 microsec clock period
T1CON.T1CKPS1 = 1
TMR1H = 0x3c ''0x3c ~ 0.1 sec/intr
TMR1L = 0xb0 ''0xb0
INTCON.GIE = 1
INTCON.PEIE = 1
PIR1.TMR1IF = 0
ADCON0 = %01000001 'fosc/8
ADCON1 = %10000100 'Dis clk div,,,an0 > an3 analaog rest dig
TRISA = %00001111
TRISB = %00000001 'reserve portb.0 for ext interrupts, if required
TRISC = %11111111
i think this is all the internal timers... maybe that is effecting my hardware in some way. the reason i think it is in here is because when i add this section to the working sample of mine the same fault appears in the hardware...
hi Jim,
Try this program, it samples every 0.1sec and displays the average of 5 samples every 0.5sec.
Use the remmed out values for BOTH the TIMER1 values when you program a PIC.
TMR1H = 0xfe ''0xcf 'FFFF - CF2C = 30D3 == 12500 * 8 = ~ 0.1 sec/intr
TMR1L = 0xfe ''0x2c
NOTE: these TIMER1 values are for a 4 MHz xtal.!
also make this =0
Define SIMULATION_WAITMS_VALUE = 1 'make this =0 for programming a PIC
Convert the LCD PORT pins to suit your project.
For my details look at my forum profile.;)
ahh, did not see that... maybe this could be something to do with it???
would it just be a matter of seeing if removing:
TMR1H = 0xfe
TMR1L = 0xfe
and replacing with:
TMR1H = 0xcf 'FFFF - CF2C = 30D3 == 12500 * 8 = ~ 0.1 sec/intr
TMR1L = 0x2c
cheers...
TMR1H = 0xfe
TMR1L = 0xfe
and replacing with:
TMR1L = 0x2c
cheers...
hi Jim,
Please confirm the frequency of the PIC crystal that you are using
The one above is for a 4mHz xtal and the TMR1H = 0x3c TMR1L = 0xb0 is for a 16mHz.
These values are ONLY for the sim
TMR1H = 0xfe
TMR1L = 0xfe
EDIT:
Where is the RW pin of the LCD connected too.?
hi Jim,
TMR1H = 0xfe
TMR1L = 0xfe
EDIT:
good morning.
will have to confirm in a little while when i get to my proper computer, but i am relatively confident it is 16MHz and that the R/W pin is not attached to anything...
also what difference does the config word (2007h) make when programming the PIC with the OS software? i have been told to set it to 3f72 though the default was 3f71...
could be part of the fault?
The LCD R/W MUST be connected to 0V if not connected to the PIC.
The change from 3f71 to 3f72 changes the Xtal select From XT to HS.
The Oshonsoft keeps setting at XT, you can try it set to HS.
If the R/W is floating your LCD will not work...:)
will iterally try attaching my LCD to ground now, see wat occurs...
at the moment it is displaying but not entirely correctly, just a solid top line and nothing on the bottom...
hi Jim
Programming a PIC OK with the last program I posted, it runs fine.
The problem is due to the Oshonsoft making the CONFIG LVP and DEBUG..
Use CONFIG: 3F32
EDIT:
Tested it using a 16F876A PIC, at 4mHz 10mHz and 20mHz, no problems.
Made up a resistive divider for an0 to give the required 4.88V with a +5Vsrc.
Checked the calibration points at 0.488V , 2.05V, 3.62V, reads 000% 00.0L... 050% 10.0L.... 100% 20L all ok.
I think your intro header screens are too fast to read.!!!
Regards
Eric
Regards
Eric
my theory too because a couple of the sample things were running ridiculously fast but i slowed them down and it worked...
how would i slow the headers down or should i just get rid of them?
really thanks for this
Even with a 4mHz the headers are to fast to read on the PIC/LED, the Percent/L readings refresh at about 2sec intervals, which you would expect for a 16mHz program..
I would use WAITMS 2000 [ 2secs for each header] the data update is 0.5secs as planned, using a 16mHz xtal.
i am just concidering if i cant get this going in the next hour or so just cutting my losses and finding a way of adapting the lcd sample that comes with it and doing the maths to get it to go between 0.5 and 3.7V and merely display 0.0-20.0L... better than nothing
Do you have a diagram showing how you have the PIC and LCD etc connected.
It works as you specified on the hardware setup at my end.
hi eric, had to cut my losses (server down at work so had no internet for whole day)...
went with this in the end:
Define LCD_RWREG = 0 'set to 0 if not used, 0 is default
Define LCD_RWBIT = 0 'set to 0 if not used, 0 is default
Define LCD_COMMANDUS = 2000 'REM'' 'delay after LCDCMDOUT, default value is 5000
Define LCD_DATAUS = 50 'REM' 'delay after LCDOUT, default value is 100
Define LCD_INITMS = 2 'REM''' 'delay used by LCDINIT, default value is 100
'the last three Define directives set the values suitable for simulation; they should be omitted for a real device
Dim an0 As Word
Dim abc As Byte
Dim suman0 As Word
Dim lit As Byte
Dim dec As Byte
TRISA = 0xff 'set all PORTA pins as inputs
ADCON1 = 0 'set all PORTA pins as analog inputs
Lcdinit 0 'initialize LCD module; cursor is blinking
loop:
abc = 0
suman0 = 0
avrg:
Adcin 0, an0
suman0 = suman0 + an0
abc = abc + 1
If abc < 10 Then Goto avrg
an0 = suman0 / 10
If an0 < 102 Then
an0 = 102
Endif
If an0 >= 757 Then
an0 = 757
Endif
an0 = an0 - 102
an0 = an0 * 100
an0 = an0 / 327
lit = an0 / 10
dec = an0 Mod 10
Lcdcmdout LcdClear 'clear LCD display
Lcdout "Fuel Level" 'text for the line 1
Lcdcmdout LcdLine2Home 'set cursor at the beginning of line 2
Lcdout "Volume: ",
If lit < 10 Then Lcdout " ",
Lcdout #lit, ".", #dec, " L" 'formatted text for line 2
WaitMs 100 'larger value should be used in real device
Goto loop 'loop forever
going to have a little fiddle with it to spruce it up a little bit tonight but it runs...
thanks
james
Lcdout "Fuel Level " 'text for the line 1
If lit < 10 Then
Lcdout "<50% Fuel "
Endif
If lit < 5 Then
Lcdout "Low Fuel: <25% "
Endif
If lit < 2 Then
Lcdout "EMERGENCY FUEL "
Endif
WaitMs 5 '000
Lcdout "EMERGENCY <10% "
Lcdout "Volume: ",
WaitMs 1 '00 'larger value should be used in real device
tried the above to get the top line to display "<50%" when fuel falls below 10L then "Low fuel" when it falls below 5L etc etc but it just seems to run them all at once... maybe i need to include an interupt somewhere?
If lit < 10 Then
Lcdout "<50% Fuel "
Endif
If lit < 5 Then
Endif
If lit < 2 Then
Endif
WaitMs 5 '000
Lcdout "Volume: ",
Once you get down to 2 liters, then you're also less than 5 liters and 10 liters at the same time, so of course all three conditionals report the corresponding fuel status for that situation. You need to set up a range for two situations, 5 liters (>2 and <5) and 10 liters (>5 and <10). I used "=>" in a few places. Without these the value concerned gets ignored and no status prints out. I tend to look for the smaller values first, so swapped the order in which the values are studied, Ie, while you you looked for 10, 5, and 2, I looked for 2, 5, and 10. What threw me is you go and print out "EMERGENCY <10%" outside of a conditional statement. Maybe I just dropped the thread here. If none of the other warnings are true, print "FUEL GOOD, >50%".
Here is my version of the code:
loop  ' Start of endless loop
... take fuel readings here...
' Detemine fuel status here, print it out.
Lcdout "Fuel Level: " 'text for the line 1
If lit =< 2 Then
Endif
If lit > 2 AND lit < 5 Then
Lcdout "<25% "
Endif
If lit => 5 AND < 10 Then
Lcdout "<50% Fuel "
Endif
WaitMs 5 '000
' Here's a problem: after determing and printing your fuel status above,
' you just print this next line out without a conditional
Lcdout "EMERGENCY <10% "  ' Try using "FUEL GOOD, >50%" here to indicate OK fuel status
Lcdout "Volume: ",
[END CODE]
Hope this helps.
kenjj
hi James,
From your latest post you seem to have the hardware and program working, in that the LCD displays OK.
I was under the impression that the LCD would only display blocks according to your earlier posts.???
If the program you have now written displays OK, there is no reason why the program I zipped for you will not work.
Its working alongside me as per your specification, using a PIC in a project board, with a range of xtals 4, 10 and 20mHz.
I would appreciate an update of what is and is not working.:)
OS v5.22 will not compile the if and functions in the same line...
Define ADC_CLOCK = 3 'default value is 3
Define ADC_SAMPLEUS = 20 'default value is 20
Define LCD_BITS = 8 'allowed values are 4 and 8 - the number of data interface lines
Define LCD_DREG = PORTD
Define LCD_DBIT = 0 '0 or 4 for 4-bit interface, ignored for 8-bit interface
Define LCD_RSREG = PORTC
Define LCD_RSBIT = 0
Define LCD_EREG = PORTC
Define LCD_EBIT = 1
Dim an0 As Word
Dim abc As Byte
Dim suman0 As Word
Dim lit As Byte
Dim dec As Byte
Lcdcmdout LcdHome
Lcdout "****************"
WaitMs 2000
loop:
abc = 0
suman0 = 0
avrg:
Adcin 0, an0
abc = abc + 1
an0 = suman0 / 10
If an0 < 102 Then
an0 = 102
Endif
If an0 >= 757 Then
an0 = 757
Endif
an0 = an0 - 102
an0 = an0 * 100
an0 = an0 / 327
lit = an0 / 10
dec = an0 Mod 10
If lit >= 5 Then
Endif
If lit < 5 Then
Lcdout "LOW FUEL: <25%"
Endif
If lit <= 5 And lit > 2
Then Lcdout "Low Fuel: <25%"
Endif
'If lit >= 5 And lit < 10 Then
'Lcdout "Fuel Level: <50%"
'Endif
Lcdout "Volume: ",
WaitMs 150 'larger value should be used in real device
can't see why it won't compile... any chance u can just post the text of the hex file on here for me?
P.S, hardware engineers on the way as we speak, already defeated 2 of them :)
