I have a project using MPLAB with the C18 compiler. The code is set to use the PIC in one of 6 hardware configurations, with different #defines in the code to properly compile everything for the setup I've #define'd. At each code release, I have to manually change the #define and recompile and export the code, which is a tedious PITA. Using MPLAB, I'd like to know how to do the following things.
1. Setup the project so a build will build the code and export the hex for each one of six #defines I have.
2. Setup the project so that the built (NOT exported) .HEX includes the EEPROM information I specify.
3. Setup the project so that the initial bootcode, from the Microchip 18F4550 USB bootloader, is included in the built hex.
Can anyone help show me how to accomplish these things?
