    Dismiss Notice
LM386 Amplifier Project
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by TheNewGuy, Aug 25, 2009.
  1. Mikebits
    Mikebits Well-Known Member
    May 24, 2008
    6,214
    174
    San Diego, Ca
    If you do a search on this site for LM3915 you will find a cornucopia of info.
  2. renekenshin
    renekenshin New Member
    Jun 17, 2010
    8
    0
    Where exactly do you put the supply bypass capacitor? Is it between the + and - supply terminals of the circuit?
  3. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,437
    933
    Canada, of course!
    ONLINE
    The circuit does not have a - supply. It has only a +9V supply and 0V. Connect the supply bypass capacitor close to the LM386 IC between +9V and 0V.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. renekenshin
    Jun 17, 2010
    8
    0
    Wow thanks for the quick reply, this forum is a lot of help, i'm currently building a stereo lm386 mini amp for my ipod :)
  6. audioguru
    Mar 16, 2004
    32,437
    933
    Canada, of course!
    ONLINE
    With a 9V supply (a 9V battery is 9V only when it is brand new) an LM386 clips when its output into an 8 ohm speaker is only 0.45W which is not very loud. A bridged TDA2922M amplifier per channel is a little louder with an output of 0.8W at clipping into 8 ohms with a 9V supply.
  7. transistor495
    transistor495 Member Forum Supporter
    Aug 27, 2008
    909
    18
    Trivandrum, India
    If you can find a SONY CXA1622P, then it would be the best choice for your application. This IC has plenty of features for its class and works on 4 AA cells. Have a look at its datasheet. Do not use LM386 for your mini amp. It's a mono amp, noisy and working voltage range is high.
    CXA1622P
    [​IMG]
  8. audioguru
    Mar 16, 2004
    32,437
    933
    Canada, of course!
    ONLINE
    The datasheet for the Sony stereo amplifier IC is a horrible translation that is missing the supply voltage for the power vs distortion curve, and its output shows mV instead of mW. If it is 6V then the output power (?) at clipping is only 0.2W into 8 ohms per channel, exactly the same as an LM386 amplifier.
    Its max distortion is a terrible 2.5% when the output is only 0.05W and is probably higher at a higher output power.
    It was made for a cassette player (remember?) so maybe it is not made anymore.
  9. transistor495
    Aug 27, 2008
    909
    18
    Trivandrum, India
    Please go through the schematic of the world renowned radio receiver that is still on production and still on top No. 1 -nothing but great SONY ICF SW-7600GR. It uses CXA1522P as it's output power amp. The radio has an excellent audio reproduction with practically zero distortion I'd say.
    Both CXA1522P and 1622P are extremely good at their job. CXA1622P is used in the DEGEN DE-1103 ,that is another great world band receiver stand at top :).
    Do anybody think LM386 will be used in these receivers? or why they didn't use I'm asking from practical side, not about some datasheet figures.
    Because LM386 is a nasty, noisy, less efficient, unworthy amp that is practically good for nothing. Making two LM386 amps as an iPod stereo amp sounds horrible for me:)
    Sony_ICF-SW7600GR schematic can be downloaded here:
    http://www.radioamateur.eu/schemi/RX/Sony_ICF-SW7600GR_serv_V1.1.pdf
  10. audioguru
    Mar 16, 2004
    32,437
    933
    Canada, of course!
    ONLINE
    I don't think Sony would use an American LM386 amplifier IC In their Japanese radio. The Sony amplifier IC is the same but is stereo or bridged.
  11. gary350
    gary350 Well-Known Member
    Dec 28, 2005
    1,097
    53
    Murfreesboro, TN 37129 USA
    Looks good but it can not possible work with no power supply.
  12. transistor495
    Aug 27, 2008
    909
    18
    Trivandrum, India
    Use of LM386 in modern era
    *)Alarm circuits
    *)Bell circuits
    *)Music tone circuits
    *)Old model radio and audio training kits and wherever audio quality doesn't matter and requires a low cost general purpose amp.
    I don't get what you mean there.. try with these batteries :D
    [​IMG]
  13. audioguru
    Mar 16, 2004
    32,437
    933
    Canada, of course!
    ONLINE
    I got free samples of those very expensive disposable Energizer Lithium battery cells. They have more power than alkaline cells and a much higher capacity. The voltage stays high until they are dead. But the very high price is not worth it unless used in a spaceship.
Share This Page
