Hi, I have a lathe that I am converting to use a 90v DC motor. I already have a speed controller that will generate the correct waveform (to drive the motor at different speeds), but it requires 90v DC inputs.
The motor can pull at max of 10A at 90v, so I need to build a 1000W AC to DC converter. Since using a full wave bridge rectifier will multiply the input voltage by √2 I need to drive it by 60 volts(AC) yielding 83 volts(DC). My question is this, can I use this transformer backwards (assuming it has no other components,diodes,etc) to take 120v mains and step it down to 60vac?
Amazon.com: Step Down Voltage Converter Transformer 1000 Watts. Converts AC 220V-110V-For use overseas in 220V/240V countries(Model VOD 1000): Electronics
Its supposed to convert 120vac to 240vac or vice versa. So it should simply be a large 1:2 transformer, right?
~LatheMan
~LatheMan
