Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
i had a doubt,what is the output of an ir transmitter and receiver pair and that of ir transmitter and photo diode.i mean wheather it is a positive one or negative i.e when lightr is transmitted high voltage is generated or low voltage at receiver?
Interestingly, there can be a voltage generated by the photo transistor, but ordinarily the IR xmitter/rcvr pair act as a switch (or to a degree, the rcvr can act as a variable resistor with a variable signal from the IR xmitter).
As such, there's no "high" or "Low" voltage generation, rather it is a voltage across the rcvr component (whether a diode or a transistor) that is being controlled.
The diode (or transistor) will, of course, have a polarity that will dictate the polarity of your connection.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
