infrared Liquid level detector-SharpGP2D12
The calc_distance() routine you are using already decodes the measurement 00-99 into 2 values;
cm10 (this is the TENS digit)
cm (this is the UNITS digit)
Then later on in oyur code in the main loop you are doign this;
//CM is higher than 09 so spilt the variable CM into 2
cmHigh = ( ( cm >> 4 ) & 0x0F ) + 0x30;
cmLow = ( cm & 0x0F ) + 0x30;
which is bad because it has already been done in the calc_distance() function.
All you need to do to display the distance in cm is this;
lcd_data(cm10 + '0');
lcd_data(cm + '0');
Which will display the 2 decimal digits (0-9) as 2 ascii digits ('0'-'9')
CoooooooooooooooooooooooooooooooooooooooooooL............................
its working hehehehehehehe.......
Thanx Guys....;)
lol now I'll have something to demo to my lecturer tomorrow...
he wanted values on the LCD even if it was wrong lol (but he will be getting the right values:D)
for objects<8cm away....the sensor gives crazy readings...otherwise its pretty accurate.....
so the range is about [8-80]
Ok this feels good...:)-its far from over though:p
still got to integrate it with the other code to give the level of the liquid...
and then i got to TWEAK IT(or PIMP MY RIDE as you'll would say:D)
i want to calculate the level of the liquid.................
*At the moment the sensor code gives the distance to the surface of the liquid.....
*the code allows the user to enter the "height" of container .....
So the liquid level=height of container-distance to surface of liquid
Now in the calc_distance function...the distance to the surface of the liquid is split into two digits..... which are displayed on a LCD.
ie. cm(units) & cm10(tens)
So do i need to send these 2 SPLIT digits from the calc_distance function to a NEW function that would combine them so that i can SUBTRACT it from the height of the container????
IS there a better solution?
Now with this code below there is a new variable called mathKeep.
If you look in the calc distance function its basically a copy of the math variable before we do anything like splitting.
Now when done using math variable we just copy our data back from the mathKeep to the math. and you can resume calculations with the math variable.
void calc_distance(void)
unsigned int mathKeep;		// [b]used for voltage calculations backup[/b]
	// from the transeiver datasheet the analog voltage is
	// the inverse of distance, so distance can be calculated
	// d = (1 / volts) then just scaled to suit the transeiver
	// load ADC value in 16bit math var
	math = ADRESH;
	math = (math * 256);
	math += ADRESL;
	// now invert it; (1 / volts) use (6050 / volts) for scaling
	math = (6050 / math);
	if(math >= 2) math -=2;		// fix linear error (-2)
	if(math > 99) math = 99;	// max limit at 99cm
	//[b]Create a copy of math for more use[/b]
	mathKeep = math;
    //LiquidLevel=height-;
	// convert from 0-99 to 2 decimal digits, 0-99cm
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	math = mathKeep;	//[b]Now our original data is back and can be used.[/b]
Could someone suggest the most suitable application for using the INFRARED LIQUID LEVEL DETECTOR???
Where would it be useful???I want to make additional features to the project but i think it would be best if i can finalize were it is going to be useful first.
EG if it will be used in a LAB....then knowing the volume of the liquid is important.
and i can write code for doing that....
the infrared detector has a range from 10cm-80cm
And any ideas on packaging the project...........?????
Have you validated that it works with various liquids, including water, yet? What is its accuracy and precision? Does it need recalibration with different liquids?
John
well im trying with water now....and it gives the craziest readings:eek:
The readings keep fluctuating!!! because of the ripples and movement on the surface...:confused:
it measures in cm......
im trying with various liquids now....
This should help reduce fluctuations. Increase the shift value to increase noise rejection, but it will slow the response.
typdef struct filter_type
   Uint16 accumulator;
   Uint16 output;
   Uint8 shift_value;
   Uint8 initialized;
filter_type adc_filter;
void Init_Filter( filter_type *filter, Uint8 shift )
   filter->initialized = FALSE;
   filter->shift_value = shift;
void Update_Filter( filter_type *filter, Uint16 new_value )
   if (filter->initialized != TRUE)
      filter->output = new_value;
      filter->accumulator = new_value << filter->shift_value;
      filter->initialized = TRUE;
   else
      filter->accumulator -= filter->output;
      filter->accumulator += new_value;
      filter->output = filter->accumulator >> filter->shift_value;
Whenever you read your adc, just call Update_Filter( &adc_filter, adc_value ). Wherever you perform a calculation on the ADC value, use adc_filter.output instead.
I haven't read your code, so I'm not positive that this is in any way helpful at all.
Trouble in paradise
:eek::eek::eek::eek::eek::eek::eek:
The readings are fluctuating.....not very stable especially for water....
i tried the detector on water, handy Andy (thick white liquid), oil......................................in a glass container and plastic container
the detector is not giving the right liquid level....
the height=height from the sensor to the base of the container
liquid level=height-distance to surface of liquid
so i only enter 1 input ie. height...... think i need to slow the sensor reading down.....
Uhmmmmm what do you guys think???im going to try the sensor on paint tomorrow.....its 21:40 now.
What can i do to improve the reading of the sensor???the most accurate reading was for handy Andy in a plastic container when it was full...
also while varying the level of the liquid .....the readings jump about in big steps
The sensor detects paper at an accurate level...BT i need it to work for liquids...is it perhaps(im scared to say this)
is it perhaps the GP2 not suitable for liquids:(
do i need to some how calibrate the sensor to enter density of different liquids and use that somewhere to improve the reading?
Please tell me what to do to improve the readings
Here is the code:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>	//
void userMenu(char pos); //
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
char WaitForInput(char expire);
unsigned char user_input(void);
void home_screen(void);
void EnterHeight(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void calc_distance(void);
void main(void);
unsigned char cm2LCD;
unsigned char posneg;
unsigned char LLHigh, LLLow;
unsigned int LiquidLevel;
#define LCD_RS RC0		//LCD RS pin
#define LCD_EN RC1		//LCD EN pin
#define LCD_STROBE()	LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10;		//
unsigned char cm;		//
unsigned int math;		// used for voltage calculations
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
//char temp[8];
//[/b]
unsigned char height=50;
unsigned char range;
unsigned char area;
unsigned char SensorPos=10;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
unsigned long bres;		// for bresenham 2-second timer system
unsigned char ;
#define HOME_SW RC2				//HOME switch
#define INCREASE_SW RC3			//INCREASE switch
#define DECREASE_SW RC4			//DECREASE switch
#define ENTERSETTINGS_SW RA4	//ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
      scale=floor(0.5+scale/10.0);
      d=(unsigned char) (n/scale);
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
      n=n*10.0;
      d=(unsigned char) n;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if	XTAL_FREQ <= 2MHZ
	do {
		DelayUs(996);
	} while(--cnt);
#endif
#if    XTAL_FREQ > 2MHZ
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
void DelayS(unsigned char cnt)
	for (j=0; j<(cnt*10); j++)
		DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
	DelayMs(2); //wait for LCD to be ready shorter delay
	LCD_RS = 0;	 //write instruction
	PORTB = (c & 0xF0); //load upper nibble on LCD data lines
	LCD_STROBE(); //send instruction to LCD
	PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
	PORTB = 0x00;
	LCD_RS = 1; //write data
    PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
	PORTB &= 0x00; //load upper nibble on LCD data lines
	PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
	lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
	j = -1;
	while(s[++j]!=('\0')) // send characters until null character reached
		lcd_data(s[j]);
/*go to beginning of line 1*/
	lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
	lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
	lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	DelayMs(20); //wait for LCD startup
	lcd_cmd(0x02);
	lcd_cmd(0x28);	// 4-bit mode
	lcd_cmd(0x08);	// display off
	lcd_cmd(0x01);	// clear display
	lcd_cmd(0x0C);	// disp. on, cursor off, cursor blink off
	lcd_cmd(0x06);	// entry mode
	lcd_cmd(0x80);  // initialise DDRAM address to zero
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
	// setup the PIC 16f690
	OSCCON = 0x72;      	// internal osc, 8MHz
	PORTA = 0;
	TRISA = 0b10010010; 	// RA7 high imp, RA3 is serial out, RA4 button input
 	PORTB = 0;          	// PORTB not used
    WPUB = 1;				// PORTB pullups ON
    RABPU = 0;
    /* Init ADC */
    ADCON0 = 0b10000101;	// bit 7 right justify,analogue channel select bits bits5-2  0001=AN1,ADC ON, RA1 is ADC input
	ADCON1 = 0b00100000;	//bits6-4  fosc/32
    ADON=1;	                // turn on the A2D conversion module
	ANSEL=0x02;            //set RA1 as analog input for GP2 sensor
	ANSELH=0x00;
    T1CON = 0b00010001;     // TMR1 is ON, 1:2 prescale, =1MHz
	T2CON = 0b00000101;     // TMR2 is ON, 1:4 prescale, =1MHz
	MyVal = 0; //initializn these variables here
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
	lcd_init(); //call LCD initialisation
//EDITED this a bit. now if expire input is set it will leave loop with a 0
//instead of rechecking this will be useful for display your measured data and
//waiting for user to exit.
char WaitForInput(char expire){
char done;
char temp;
done = 0;
temp = 0;
while(!done){
    if(!ENTERSETTINGS_SW){
		while(ENTERSETTINGS_SW);
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
	if(expire == 1) break;
}//end of while
    DelayMs(150);    //debounce
    return temp;
void userMenu(char pos){
    unsigned int delaytime = 100000; // 100ms CHANGE THIS FOR YOUR BELOW DELAY
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			lcd_puts("    HEIGHT    ");
			break;
		case 1:
			lcd_puts("    RANGE     ");
			break;
		case 2:
			lcd_puts(" SURFACE AREA ");
			break;							//
		case 3:
			lcd_puts("   MEASURED   ");
			 while(WaitForInput(1) != 2){		//Wait for user to press enter to leave loop
 				// wait for 2 seconds, uses TMR1 free running at 1Mhz
   				while(!TMR1IF)  		// wait for TMR1 overflow
				TMR1IF = 0; 			// clear overflow flag
				bres += 65536;			// add 65536uS to bres value
				if(bres >= delaytime )		// if reached 2 seconds!
    				bres -= delaytime ;	// subtract 2 seconds, keep error
					// read the ADC voltage RA1 (Sharp GP2 sensor)
					GODONE=1;					// initiate conversion on the channel 0
					while(GODONE) continue;  	// Wait convertion done
					calc_distance();			// convert ADC value to distance
					lcd_goto_L2();				//Only change line 2
					if(posneg == 'p')
						lcd_data('+');
					else
						lcd_data('-');
					lcd_data(LLHigh);
					lcd_data(LLLow);
	    			lcd_puts(" [cm] ");			//comment this out if you want
		lcd_goto_L1();
		lcd_puts(" Loading Home ");
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	if(pos == 3) return;
	lcd_goto_L2();
	lcd_puts("Press Up/Down"); //home screen message (line 2)
// New Menu System
void EnterHeight(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" ENTER HEIGHT ");
	lcd_goto_L2();
void EnterScreen(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
void ShowDigits(unsigned char val){
    MyValLCD[0] = val /10;    //returns the quotient (if temp = 35 the result is 3)
    MyValLCD[1] = val % 10; 	//Returns remainder   (if temp = 35 the result is 5)
	MyValLCD[0] += 0x30;	//to ASCII
	MyValLCD[1] += 0x30;	//to ASCII
	EnterScreen();
	lcd_goto_L2();
	lcd_data(MyValLCD[0]);	//to LCD
	lcd_data(MyValLCD[1]);  //to LCD
	unsigned int tmp;
unsigned int mathKeep;		// used for voltage calculations backup
	math = ADRESH;
	math += ADRESL;
	//Create a copy of math for more use
	mathKeep = math;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	math = mathKeep;	//Now our original data is back and can be used.
	//This will check if negative
	LiquidLevel=height-math;
	posneg = 'p';
        if((LiquidLevel < 0) || (LiquidLevel > 0xFF00)){
		LiquidLevel = -LiquidLevel ;
		posneg = 'n';
	//if below zero which will be in the 0xFFFF range i just chose any 0xFFxx number :D
      //LiquidLevel is higher than 09 so spilt the variable LiquidLevel into 2 //
      LLHigh = ( LiquidLevel / 10 ) + '0'; //
      LLLow = ( LiquidLevel % 10 ) + '0';  //
unsigned char user_input(void)		//This will return what we want
	char done = 0;
	MyVal = 0;			//Start on 0
	while(done == 0){
   	  input_sw = WaitForInput(0);
      switch(input_sw){
		case 1:
			done = 0xff; 			//This tells us the user finished entering
			lcd_goto_L1();
			lcd_puts("      OK       "); //home screen message (line 1)
			break;
      	case 3:
			if(MyVal < MyMaxVal)
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
			if(MyVal > MyMinVal)
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
void home_screen(void){
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
	lcd_goto_L2();
	lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
	input_sw = 0;			//Reset the value
	while(input_sw != 1)  	//Wait until enter is pressed
	userMenu(0);
	DelayMs(2);				//shorter delay
    height = user_input();	//The HEIGHT var will have the myVal
	userMenu(1);
    range = user_input();	//The HEIGHT var will have the myVal
	userMenu(2);
    area = user_input();	//The HEIGHT var will have the myVal
	userMenu(3);
//Waits for user to press ENTER to show home screen
"enter height"
call enter/settings (which is now user input function in new code)
height=MyVal
"enter range"
call user_input
range=MyVal
"enter surface area"
call user_input
area=MyVal
/*  Junebug_Serial4.c    RomanBlack.com 19th July 2009.
    uses "zero error 1 second timer"
	system to generate a 2 second interval, then every
	2 seconds it reads an analog voltage from a
	Sharp GP2 distance sensor and converts it to decimal
	distance, then sends that data to a LCD
	Code for MikroC, config handled by MikroC compiler;
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
void main(void)
    init();	// initialise I/O ports, LCD
    while(1){
 	home_screen();
 /*// wait for 2 seconds, uses TMR1 free running at 1Mhz
	if(bres >= 2000000)		// if reached 2 seconds!
    	bres -= 2000000;	// subtract 2 seconds, keep error
	//	LiquidLevel=height-;
	//	lcd_clear();                // Using the new menu you can erase or
	//	lcd_data(cm10 + '0');
	//	lcd_data(cm + '0');
	 //   lcd_goto_L2();
	   // lcd_puts("[cm] ");			//comment this out if you want
This may attribute to part of the wrong readings:
The Linearizing Function
According to page 10 of the Sharp Device Specification for Distance Measuring Sensor Model No. GP2D120, a plot of the following interpolated equation is demonstrated:
V = 1 / ( R + 0.42 )
Where V is voltage and R is range, the equation produces a very straight line. The division operation acts as a linearizing function that turns the ungainly curve into a linear plot. This observation is the key to finding a simple approximation function for a Sharp IR range finders.
The constant in the linearization function depends on the sensor type and calibration data parameters. The value of 0.42, as shown above, works well for the GP2D120 and the calibration points in the Sharp document, but may not be suitable for other sensors.
Not just V = 1/R
im using the sharp GP2D12
I could use a float.............what would be a good float????
i must try that later lol MAYBE that white paper that the detector works with:D
Any suggestions.....
is there a better solution than a float???
Not just V = 1/R
That was already covered here (fix linear error -2)
Which i hand tuned and tested for the 10-80 cm sensor. The linear error is caused by the geometry of the optics. Sicne they are on different angles in the 4-30cm sensor and the 10-80 cm sensor you need a slightly different value. However my value of 80cm -2 (its ratio) is not too different from the Sharp datasheet for the 4-30cm sensor -0.45.
fantabulous- you've taken a couple of steps backward! You should average a number of sensor readings to smooth it out (Noggin already gave a method).
And testing if the sensor is detecting the top or bottom of the container was what you were doing right at the start (with all the charts etc)...
OK, I just went and dug out my connector cable Junebug and Sharp sensor. I only had the 4-30 cm sensor handy so that was the one I tested.
I filled a big plastic jug with about 9" of water, and set the sensor looking directly downward.
The results are a bit inconclusive. With the sensor EXACTLY perpendicular to the water surface it measures the surface. With the sensor tilted just a couple of degrees it measures the bottom of the jug (blue plastic). With the sensor almost perfect it sometimes even measures the average (distance between the top and bottom of the liquid), the sensor analog electronics must be averaging the two returned signals.
With longer distances the sensor finds it a bit easier to measure the top of the liquid, but with the top of the liquid gets too close (ie under 10cm) it starts to give preference to the bottom of the liquid. This is inline with my earlier findings that the sharp sensor tends to ignore transparent windows if they are pretty close, which is probably a design feature since the sensors are often mounted behind plastic windows in appliances.
So to summarise;
1. it WILL measure the top surface of clear water if the sensor is aligned to exact perpendicular, this obviously increases the reflection strength from the surface of the water. It may be workable with a sturdy and fine adjustable sensor mount.
2. It is much more reliable measuring the top surface of the water when that surface is further away from the sensor.
3. Anytime the water sloshes (changes surface angle relative to the sensor) or the sensor angle changes slightly, or the water is very close to the sensor, there is a high probability of reading the bottom of the container OR an average of top/bottom of the water.
4. I wetted a fluffy black sock and placed it in the bottom of the jug. That's about as non-reflective as you can get. No difference, if the sensor setup is perfect it reads the top surface, if not, it reads the sock (bottom) or maybe a weird average.
I tested a couple of different water heights and some deliberate sensor angles, basically the same conclusion; if the sensor is JUST RIGHT it reads the top surface of the water accurately.
I didn't test a light colour (white) for the jug bottom, only the blue plastic and black sock. Given the Sharp sensor's ability to negate colour differences I can't see it making any real difference, at least I saw no difference between the blue and black.
Thanks ALOT MR RB:eek::eek::eek::eek: ......Sorry for inconveniencing you
Think I must add a level eye to this design.....
What if you made a floater by cutting a sheet of thin plastic with dimensions slightly smaller than the container so that it can move up and down freely? You may need to add guides by poking a few holes in it and inserting something like straightened clothes hangers. You may also find it difficult to keep it from sticking to the bottom of the container when filling it after completely empty.
Or throw a handful of ping-pong balls in there
