chinsoon said:by the way, i heard a some people saying that for RF circuits, its not so suitable to test it on bread board. it will cause error. just want to seek for opinions of all of you here about this. is that true?
Nigel Goodwin said:Yes, breadboards are not suitable for RF, and are barely suitable for audio frequencies!.
gramo said:It’s the capacitance that the traces create along the tracks on a breadboard. Think of each track as a capacitor, with 2 sheets of metal and air as the dielectric
chinsoon said:so whats the reason behind it? with breadboard, RF circuit definitely will not work is it?
so i have to constuct them on a PCB instead?
Nigel Goodwin said:Or stripboard?, but again you need to be careful with the layout, and remove unused tracks and parts of tracks. The same applies to a PCB as well, you need to consider the layout if you expect it to work, and the higher the frequency the more critical it is.
chinsoon said:ok...thats something new... actually this is the first time i am involve in this kind of project..
so i've done google.... and it seems like what you suggest, a stripboard is quite easy to use... so it works for RF 27MHz is it? so i think i will redo my first circuit again.
and nigel, you've seen my first circuit right? in the very beginning of this thread? theoretically it should work (like what you mentioned last time in this thread as well), but is there any possibility that the values given are wrong and the circuit will not work. i mean from theory side, i think it should work. but practically, will it?
