chinsoon said:wow... now these i don really understand...
so how am i suppose to tune the NE567???
What do you think the 22K pot on pin 5 is for?.
chinsoon said:thanks to Audioguru and RadioRon who taught me how to modify it, i managed to pull up the output voltage of the NE567 from 1mV to 3mV ( i donno how it happened)... but still not enough to trigger the relay...
bananasiong said:This device operates at 27 MHz right? What's the purpose of the tank circuit of the transmitter (39 pF and L2)? And is the modulatind signal coming from the 555 timer which is 584 Hz?
audioguru said:Your first schematic has a missing resistor in series with the base of the BC307 transistor that causes the output transistor of the NE567 to blow up and maybe also the base of the BC307 to blow up.
The output of the NE567 is the collector of an NPN transistor that is trying to go to ground but the base of the BC307 is holding it at 0.7V less than the positive supply with a very high current.
The BC307 is also missing a resistor to turn it off.
The BC307 might not be required since the output of the NE567 can drive a 100mA load (that is connected to the positive supply) directly.
The circuit is missing a diode across the coil of the relay to arrest the inductive voltage spike produced when the relay turns off.
The capacitor at the output of the NE567 is not recommended.
Nigel Goodwin said:You've connected the transformer the wrong way, and probably blown the chip?.
chinsoon said:Em.. there is such possibility. I mean i cant find any information or the way to connect the IFT. So i did it based on the circuit diagram. It shows that the input side has 2 pins and the output side has 3 (something like a center tap) so i followed accordingly. is that wrong?
By the way. is there any possibility that this circuit will not work. As in i got this from a website that did not state that it is tested. So my lecturer is questioning whether is this the issue or not.
bananasiong said:Hi,
According to the datasheet, the maximum frequency, fo is 500 kHz, but the minimum is not stated. I've tried with 5 kHz, but it doesn't work as expected. The output seems to be oscillating. When I change the fo to 200 kHz, then it works. Pin 8 goes low when the variable resistor is tuned to match the input frequency.
From the datasheet as well, the maximum input voltage is 200 mVrms. Is it going to be damaged if the input signal is higher? Up to 2 Vpp?
