    Dismiss Notice
Having issues with my power supply
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by Zachary Lazauskas, Sep 18, 2017.
  1. Zachary Lazauskas
    Zachary Lazauskas New Member
    Sep 18, 2017
    4
    0
    O built a power supply several months ago and it worked fine. It measured all the right voltages at the correct spot. But now when I went to go and fix some of the wires connected to the pretentsheomiter that got diconnected. Then all the sudden the resistor starts to smoke for some reason. I am very confused by this and would like some other ideas on why.
  2. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    11,056
    541
    AZ 86334
    Welcome, Zackary,
    The reason that resistors smoke is that you exceed the power dissipation rating of the resistor! Heating of a resistor is (more-or-less) proportional to the power dissipated there-in. Resistors have power ratings, like 1/4W for a small film resistor up to 10s of W for large cement or wire-wound resistors. Pots are usually 1W or less.
    What did you smoke? Post a schematic and indicate which resistor got hot.
  3. Zachary Lazauskas
    Sep 18, 2017
    4
    0
    well this was a school project, and I probably can't find the schematic again. But I can tell you that there is one resistor in the circuit [a 90Ω 5% restistor]. I
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,902
    502
    Cleveland, OH, USA
    At 12 V across it, that resistor should be at least 2 W, 4 W or more would be better. The resistor should be labeled. Assuming it has leads, it should be the diameter of a pencil or larger.
    My concern focuses on your problem statement. Namely, that the power supply worked fine until you "fixed" wires attached to the potentiometer. That is where I would look for problems, and without knowing what the potentiometer does or how the wires are attached to it we will all be at a loss.
  6. Zachary Lazauskas
    Sep 18, 2017
    4
    0
    Last year was my first year, so I was looking over my work again for improvements and I replaced a short wire and got a longer to replace. But it was only one wire though. I'll give you a picture towmorrowwhen I get into the shop.
  7. Zachary Lazauskas
    Sep 18, 2017
    4
    0
    I some how fixed the problem. I replaced the heat sink, the resistor, and the protagonist and it's now fine. I do what the bad part was.
  8. atferrari
    atferrari Well-Known Member
    Oct 8, 2003
    2,812
    121
    Buenos Aires - Argentina
    But, did you actually alter the circuit, right?
Share This Page
