Fpga
Looks like a good starting point for FPGA's, that first book you mention FPGA 101 I think I have that as an E-Book, I have a few E-Book resources about FPGA's, just haven't had a chance to look at them yet, if you want any let me know!
Trying to create some blink code and get a crazy error:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity BlinkLed is
	Port (
		led0 : out STD_LOGIC;
		clk : in STD_LOGIC
end BlinkLed;
architecture Behavioral of BlinkLed is
 begin
	synchronous_description : process(clk) is begin
			if rising_edge(clk) then
			    led0 <= '1';
			else
				 led0 <= '0';
		   end if;
   end process;
end Behavioral;
My UCF file:
NET "clk" LOC = "P89" | IOSTANDARD = LVCMOS25 ;
NET "led" LOC = "P86" | IOSTANDARD = LVCMOS25 ;
My Error:
ERROR:Xst:827 - "C:/XWD/BlinkLED/BlinkLed.vhd" line 34: Signal led cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release.
i even tried without the "rising_edge(clk)" the long way... (change the variable names also)
library IEEE;
entity BlinkLed is
    Port ( LED_01 : out  STD_LOGIC;
           OSC_IN : in  STD_LOGIC);
end BlinkLed;
begin
	process (OSC_IN)
	begin
		if (OSC_IN'event and OSC_IN = '1') then
			LED_01 <= '1';
		else
			LED_01 <= '0';
		end if;
	end process;
end Behavioral;
Still a no go :(
Ok the problem was:
"OSC_IN'event "
But why i cant use it is a mystery... really. What its used for is also a mystery heh. i assume its to tell me if the clocked changed states and the next item checks if the state is 1...
You code appears wrong. Try this:
if(rising_edge clk)
LED_01 <= not LED_01;
Make sure you initialize the signal. Try using a reset signal
if(rising edge clk or falling_edge reset)
if(reset = '0')
LED_01 <= '0';
else
something like that. My syntax may be a little off, long time since I wrote VHDL, but hope you get the idea...
For your simple example, you can get away without it -- in synthesis. But your simulation tools won't be able to simulate it correctly. Any sequential design you do that is more complicated, always use reset for initialization.
Here is a clean way to do it:
process(clk, reset) then
if(reset = '0')
elsif(rising_edge(clk)) then
end if;
Ok cool thanks, but just to let you know i have seen tons of designs without the use of it. But ill be sure to use it. I think i better understand it now also
I've seen tons of poor design practices too. Better to learn the right way out of the gate.
heh yeah thats true. Ok to be sure i understand...
This code synthesizes ok
	process(OSC_IN, RESET) is begin --Handle the inputs
	if(RESET = '1') then  --if RESET is high then  set the LED to low (off in my case)
		LED_01 <= '0';
	elsif(rising_edge(OSC_IN)) then //If RESET is LOW and the RISING EDGE of clock is hit then turn LED on
		LED_01 <= '1';
	end if;
How would i turn off the LED off when the Clock is LOW then ?
do i simply add after that ?
--AFTER IT ADD
	if(OSC_IN = '0') then
		LED_01 <= '0';
	end if;
or
--AFTER IT ADD
	if(falling_edge(OSC_IN)) then
		LED_01 <= '0';
	end if;
The below seems to synthesize ok and simulates fine
library IEEE;
entity BlinkLed is
           OSC_IN : in  STD_LOGIC;
			  RESET : in STD_LOGIC);
end BlinkLed;
begin
	  LED_01 <= '0';
	  LED_01 <= '1';
	end if;
	  LED_01 <= '0';
	end if;
	end process;
end Behavioral;
You don't trun off the LED when the clock is low. You turn it on and off on alternate clock periods, using this line as I've written above:
LED_0 <= not LED_0;
on each clock edge, the LED will change states.
Take a look at the simulation image... As you can see when RESET is low it allows the LED to be controlled and when high even with a clock still coming in the LED is held low...
sim-jpg.55770
LED_0 <= not LED_0;
Ah i see now.. cool thanks... since i didnt copy paste i missed that :D
If i do that then to synthesize i need to make the PIN inout type to be able to read the current state. Otherwise i get a error...
Here it is tho.. now i see what i was doing heh.. trying to change it on half a clock really.
sim-jpg.55771
