    Dismiss Notice
electronic rust protection for cars
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by rayr5, Feb 12, 2005.
  1. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    Phosphate treatment of steel is a widely accepted method to provide rust protection. A common name for it is Parkerizing.
    John
    • Informative Informative x 1
  2. Speakerguy
    Speakerguy Active Member
    May 24, 2007
    1,473
    15
    USA
    Well hell, they've been Parkerizing gun finishes for years. Glock even Parkerizes their finishes after their supposedly magic Tenifer process.
  3. dknguyen
    dknguyen Well-Known Member
    May 6, 2006
    6,668
    64
    Why use a battery when you could just buy a block of magnesium and put it into contact with the material as a sacrificial anode? Smaller, cheaper, lasts longer. I'm not even sure how batteries would work current needs to travel in a loop so it seems to me you would just be shorting the battery across the metal part.
    EDIT: I see somebody mentioned capacitve coupling. I can see how that would work, and be better than just using a large resistor to limit current.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. arrie
    arrie New Member
    Jun 9, 2008
    641
    7
    Honeydew, Jhb, RSA
    Would it not be easier to buy a plastic or carbon fibre bodied car?
    Why new cars last better than old ones regarding rust is a very new technology called galvanized steel. Really.
  6. dknguyen
    May 6, 2006
    6,668
    64
    Definately not as cheap though :D
  7. arrie
    arrie New Member
    Jun 9, 2008
    641
    7
    Honeydew, Jhb, RSA
    Funny enough.
    I still cannot see why plastic body manufacturing should be so much more expensive than steel. Then we are not even starting with aluminium-alloys, very popular today by so-called luxury vehicle manufacturers.
    Wonder why.
  8. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
    Plastic isn't as strong as steel and neither is aluminium.
  9. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    Not quite sure what you mean by strong. For example, by weight, a lot of composites and aluminum alloys are stronger than steel. The 7000 series aluminum alloys (e.g., 7075 and 7068) are casually referred to as stronger than mild steel by hardness and tensile strength.
    John
  10. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
    I'm not talking about by weight, I mean by volume. Plastic is a lot less dense than steel and so is aluminium. Also, the composites that can outperform steel are a hell of a lot more expensive.
    If you thing that there's another material stronger than steel that's cheaper, then why aren't they already using it?
  11. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    You have now added another limiting condition, namely cost. But, that wasn't included in your original statement with regard to strength.
    Also, by volume, the aluminum alloys I mentioned (and some others) are stronger and harder than mild steel. Carbon fiber, by volume has a lot greater tensile strength than steel and weighs less. In fact, it cannot be cut well by HSS.
    The use of steel over composites and aluminum boils down simply to cost in many cases. Ease of fabrication is another issue, as many strong aluminum alloys are very difficult to weld.
    John
  12. rjvh
    rjvh New Member
    Dec 20, 2007
    863
    6
    cambodia
    But kevlar is fibers can be used in a woven pattern and reinforced with polyester for shape and smooth finishings
    it's only that fabrication costs are higher than conventional methodes
    partly because it requires a different production line and that is a huge investment
    matterial is deerder but could be competative if the demand whas bigger so more would be manufactored
    the clasic who was first chicken/egg story
    Robert-Jan
  13. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,222
    641
    Derbyshire, UK
    They use steel because it's CHEAP and easy to use, pressing body panels out in seconds and simply spotwelding them together. There 'may' be cheaper materials, but they aren't as cheap to construct with.
    As for strength, a fibreglass bodied car is probably stronger than a steel one - but again cost is the issue, you need a chassis to build the car on, and lots of labour to create the body, rather than simply stamping out and spotwelding.
    • Like Like x 1
    • Agree Agree x 1
  14. BaCaRdi
    BaCaRdi Member
    Apr 7, 2008
    233
    2
    Hoboken / NYC
    Great Idea with the Sacrificial anode! I know I have seen this before, I just can't remember where or what industry it was. I remember replacement blocks of metal as they wore out...
    EDIT: AHH I remember it was in the fish hobby, a carbon dioxide generator:)
    -BaC
  15. BaCaRdi
    BaCaRdi Member
    Apr 7, 2008
    233
    2
    Hoboken / NYC
    Yes and metal is very forgiving to work with, this is why I love working with metal. If you screw up you can start over and try again! If you bend it wrong, bend it back, if you make a tear or hole, you wield it, if all else fails melt it and start over! You wonder why even artist use metal as media;) Try that with carbon fiber..hehe
    -BaC
  16. arrie
    arrie New Member
    Jun 9, 2008
    641
    7
    Honeydew, Jhb, RSA
    I agree, steel is a great medium. Enjoy working with it myself.
    But, most cycles are made of some alu-alloy, or what about CroMo, who remembers that. Cycles made from is this is just about the same price as the equivalent steel ones.
    Interesting. CroMo is much stronger and lighter than steel. I also think if used more, it will become cheaper. But I doubt CroMo will be suitable for body panels, but great for chassis and suspension components, nowadays manufacturers are switching to alu to limit unsprung weight, etc.
    CroMo would be better option I think.
    But for some funny and possibly political reason I'll be wrong again.
  17. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    If by "CroMo" you mean chrom-moly (in American), that is just another alloy of steel. Most often it is 4130, which is used extensively in aircraft too.
    It is a very strong alloy, but should be welded, not brazed for critical applications, unless one is specially trained. If you aren't careful in brazing, you can get intergranular cracking over time.
    One advantage of aluminum and "plastics" over steel is the variety of adhesives that are available for them. Sure, adhesives can be used for steel, but surface prep and bonding are well defined and very strong for both composites and aluminum alloys. Some of the proprietary methods of bonding aluminum used in aircraft (see: Boeing) are extremely strong, and because of the large surface area available in sheet bonding, they are preferred to riveting in certain applications.
    John
  18. arrie
    arrie New Member
    Jun 9, 2008
    641
    7
    Honeydew, Jhb, RSA
    Yip, that's the one.
    You seem to know a bit about the different materials.
    I've only in the past worked with wood, mild steel and few forms of plastic, like PE(very basic things done here).
  19. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    One of the neat things about PE and related plastics is the ease with which they can be welded. As you know, adhesives are not particularly good for them because of their slippery nature. However, hot-air welding is easy and gives a great joint. The technique is a bit different than for steel. Rather than forming a puddle and adding filler, with plastic, you push the filler into the joint. Effectively, there is no puddle, just surface melting.
    Try it, you'll like it. John
  20. Nigel Goodwin
    Nov 17, 2003
    39,222
    641
    Derbyshire, UK
    Interesting to hear that, I presume it only applies to that alloy? - we were always told that motorbike frames (and push bikes) should be brazed, because the vibration pass through the brazing, whereas they stop at the welds and tend to crack the welds over time.
  21. arrie
    arrie New Member
    Jun 9, 2008
    641
    7
    Honeydew, Jhb, RSA
    Nigel, but surely motorbike frames are not made from the same material as cycle frames.
    Motorbikes uses an alu-alloy, isn't it. Or maybe just some.
    I still remember the days when motorbike frames were mostly steel as well.
    Then after that everyone seemed to have a fling with alu.
Share This Page
