    Dismiss Notice
Electronic Door Lock keypad with Arduino
Discussion in 'Arduino' started by StealthRT, Sep 13, 2012.
  1. StealthRT
    StealthRT Member
    Mar 3, 2009
    172
    1
    Hey all i have a project i am interested in doing. It involves an Arduino and a Kwikset 909 Smartcode Electronic Deadbolt. I am looking to program the Arduino to mimic me pushing the keypad on the deadbolt face so that it will unlock using my cell phone, webpage, etc etc since the Arduino will be hooked up using the Ethernet Shield to a web server at the house.
    The image of the deadbolt unit is this:
    [​IMG]
    Problem being is that i do not know how to go about using the arduino to "push" the buttons since they seem to have 2 digits per button. Also, how would i go about wiring them up so that i only have to use one ground wire for each button so it minimizes the wiring i'll have to use?
    Is this possible? What would the wires to each button need to be? Positive or negative to trigger the button?
  2. alec_t
    alec_t Well-Known Member Most Helpful Member
    Jul 10, 2011
    9,251
    1,218
    Cardiff, Wales
    Are there also two switches per button?
    Does that unit contain any electronics?
  3. StealthRT
    StealthRT Member
    Mar 3, 2009
    172
    1
    Ok i will be picking this lock up today so i will be sure to post images of the housing and electronic board to better give a visual as to what all i need to do.
    I guess i could hook up to the relay but i am not sure if their software checks for anything and locks it out if the keypad is not used or what not?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. dr pepper
    dr pepper Well-Known Member
    Oct 6, 2008
    4,645
    246
    North west UK
    Embedded controler applications often have multiplexed keypads, there is a common for every row and a common for every column, the micro scans the pad to see which if any button has been pressed.
    Being only a 6 button pad you might be lucky and each button may have its own connection to the micro and have a common ground, check the traces, the unit may still have a multiplexed keypad, esp if the same software is used on other products which is often the case.
  6. StealthRT
    StealthRT Member
    Mar 3, 2009
    172
    1
    What i plan to do with it is this:
    Create an Android App that runs in the background and after 5pm it checks every 3 minutes the GPS lat & long of my position and when I'm around the house it will send a command to the server and it will unlock the door before i get to it from my driveway.
    I just wanted to make sure i would be able to mod the deadbolt first since i have not seen any Google listing s for the model i will be purchasing.
  7. KeepItSimpleStupid
    KeepItSimpleStupid Well-Known Member Most Helpful Member
    Oct 30, 2010
    9,913
    1,095
    I would guess that pushing longer activates the second number and possibly the "beep" response is different if there is one.
  8. StealthRT
    StealthRT Member
    Mar 3, 2009
    172
    1
    Just an update... I haven't forgotten about doing the pictures. Just been busy moving in to the new home. Will get those done tonight!
  9. dr pepper
    Oct 6, 2008
    4,645
    246
    North west UK
    Know exactly how you feel there, I moved 2 weeks back, stuff everywhere.
    My 'shop is still in boxes.
    My engineering stuff filled a 4.5 ton truck full.
  10. StealthRT
    StealthRT Member
    Mar 3, 2009
    172
    1
    Back to the drawing board....
  11. 3v0
    3v0 Coop Build Coordinator Forum Supporter
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    The keyless entry on my wife's car has 2 numbers on each button but they are just the one switch. Pushing 135 is the same as pushing 246.
  12. alec_t
    Jul 10, 2011
    9,251
    1,218
    Cardiff, Wales
    S1 is a 4-bit switch, suggesting there are only sixteen combinations the lock can be set to. Is that the case?
  13. StealthRT
    StealthRT Member
    Mar 3, 2009
    172
    1
    Sorry again for the delay! Moving into a new home and having boxes everywhere kinda slows down the process of modding stuff.
    I should have some time today to test out the motor and see if it reverses and also what voltages it uses.
  14. StealthRT
    StealthRT Member
    Mar 3, 2009
    172
    1
    deleted to start over...
  15. StealthRT
    StealthRT Member
    Mar 3, 2009
    172
    1
    Well I applied 5v to those 2 pins and whatcha know it... yeah you guessed it.
  16. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    Could be that there are some fixed bits/digits in the combination. Sort of like they do with I2C chips.
  17. StealthRT
    StealthRT Member
    Mar 3, 2009
    172
    1
    Hum well i went ahead and bought this one for now (LockState LS-DB500R-RB [​IMG]). I will be ordering another replacement again sometime soon and will update this post when i have! :)
  18. kiosk
    kiosk New Member
    Jul 19, 2011
    17
    0
    I was also given the same requirement by my professor but the difference is that I will use a keypad, arduino and an LED display. Any idea how to do it? please reply
  19. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    Break the problem down. Pick one part and get it working then move on to the next.
    I am sure you can find ardunio tutorials for each part.
    When you have each bit working combine them.
    To tell you much more would rob you of the learning experience. Aka waste the money you are using to attend the uni.
  20. kiosk
    kiosk New Member
    Jul 19, 2011
    17
    0
    i found this on the internet. my problem now is how to put the LCD display because my microcontroller has limited inputs.
  21. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,798
    134
    morristown,tn
    You can use the analog pins as digital
Share This Page
