Current going through my resistors
ad353
hello all!!
i have three resistors that i have in parallel,
they are
120
270
560
what is the current that would be flowing throuh them?
i know you need to use kirchoffs or ohms law, but i jsut dont get it, can any one let me now what the current flowing thrtough them is?
thanks guys
adam
The current through the 120 Ohm resistor will be := 8333A
The current through the 270 Ohm resistor will be := 3704A
The current through the 560 Ohm resistor will be := 1786A
remember you didnt say what voltage the supply was at ;)
This sounds like homework. Parallel resistor are easy. They all have the same voltage across them and you know what the resistance is, thyus use ohms law to calculate the current flowing through each one
the voltage going in is 10v
i know i have to use sumin like this
Vs = V1 + V2 + V3
Therefore I would have to use
Vs = Vr1 + Vr2 + Vr3
is this on the right line?
adam
no!!!!
here is a clue, the voltage I used was 1million volts so frm that, you have the resistance and also the current I calculated.
Work through my calculations to find out what I did
This is a fundemental thing in electronics (Omhs law, Kirchoffs current and voltage law). If you cant get your head round those three and just get the answers you will struggle alot later
keep going...
Remeber Kirchoffs current law
"current entering a node must leave that node"
almost there
i getting there
The current through the 120 ohm resistor will be := 0.08333A
The current through the 270 ohm resistor will be := 0.03704A
The current through the 560 ohm resistor will be := 0.01786A
jsut trying to get my head around the next bit of kirchoffs law
adam
so the total current
using kirchoofs current law
is 0.8882a
so that would be how much currentis going through the three resistors in the curcuit?
adam
No
you just calculated how much current was going through each resistors. so what is the total current...
REmember kirchoffs current law. := the first current node is the voltage source to the 1st resistor. Current enters that node. Then current leaves that node and goes through the 3 resistors
Nigel Goodwin said:
The total current is just the sum of the three individual ones, simply add them together - ohms law is all you need to know for this question.
I was trying to get him to figure it out ;).
Well good use of my day off sick
YES!!!!!!!
but the real question is do you know why?
*cough* Energy conservation *cough*
