    Dismiss Notice
Convert
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by VoCoDeR, Jan 4, 2003.
  1. VoCoDeR
    VoCoDeR New Member
    Oct 19, 2002
    1
    0
    Greece
  2. bogdanfirst
    bogdanfirst New Member
    Dec 13, 2002
    1,310
    1
    Ramnicu Valcea, Romania
    do u mean that u want instead of a potentiometer to use 2 buttons one to turn the voltage up, the other down and same for the curent......something like a digital volume control?
    well u could use a 22or 10 stage up/down cunter and some resistors for the output, so for each resistor u change u have a different voltage...
  3. herbymcduff
    herbymcduff New Member
    Dec 5, 2002
    205
    0
    USA
    It looks like you built a variable voltage and current power supply. Cool. But its only variable because of the pots. Then you said that you wanted to use 4 buttons, 2 for volts, 2 for current. You could do that, but you would only have 2 different voltages and 2 different currents. Then its not that variable.
    You would probably have to do something like bogdanfirst said. I would say go with the 22 counter so you can vary it more. But you would never be able to get the varability a pot gives you.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. mechie
    mechie New Member
    Sep 4, 2002
    591
    3
    Lincolnshire, England
    More resolution?
    If an 8-bit binary up/down counter was used then with some binary-weighted resistors (8 of them!) you could achieve a much better resolution - setting the output to the nearest 10th of a volt (ish).
    With two of them cascaded for 16 bits ....
    . . . makes you think about poxy old noisy pots don't it :?:
Share This Page
