    Dismiss Notice
C18 Questions
Discussion in 'Microcontrollers' started by 3v0, Jun 25, 2009.
  1. 3v0
    3v0 Coop Build Coordinator Forum Supporter
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    This thread is a continuation of C18 related off topic posts in Junebug Help.
  2. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    IO Port Masking in C18
    In JPUG#1 Multiplexing Charlieplexed Displays masking was discussed in the context of charlieplexing. The text regarding masking is discussed in the section: setLatA(), setTrisA() on page 5.
    Although the article is specific to manipulating the Junebug's charlieplexed leds it should provide a good general explaination of how masking is used in relation to IO ports.
    I am open to suggestions.
    3v0
    EDIT: Added link to JPUG#1 as suggested by Pommie. See his (the next) post for the link to the JPUG index.
  3. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,008
    316
    Brisbane Australia
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,793
    134
    morristown,tn
    Atom did a real good tip and tricks pdf for the C18 it here
    http://atomsofttech.no-ip.info/tempdl/AtomSoftTechC18_v8.pdf
    This would be a good one for MrDeb http://www.blueroomelectronics.com/JPUG/JPUG_02_June2008.pdf and if he reads this down load it and read page 6
  6. Triode
    Triode Member
    Feb 11, 2009
    925
    22
    Bay Area
    Moved this from the junebug thread:
    Thats what I thought "bits" did. In the example on multiplexing in JPUG1 masking is used to change some bits without chaning others, is it done that way because they are changing several bits at once and want to avoid changing the non targeted ones?
    and to make sure Im generalizing this properly from your example
    Code (text):
    TRISBbits.TRISB1=0; or TRISB&=0b11111101
    if I wanted to set port A pin 0 to input, I would type:
    Code (text):
    TRISAbits.TRISA0 = 1;
    and if I wanted to set port B pin 0 high, assuming its an output according to TRISB, i guess it would be:
    Code (text):
    PORTBbits.PORTB0 = 1;
    Im totally guessing on the PORTB0 part, but thats the kind of thing I could find in one of these microchip PDFs isnt it?
    (I'm just explaining this to see if i have it right)
    TRISB&=0b11111101 will only shut off pin 1 or anywhere you insert a 0. and if you wanted to set some high without effecting the others you would OR it with a line of 0's where you wanted no change, and a 1 where you wanted it to definitely come out high.
    so for setting port A pins 1 and 3 high would I type:
    Code (text):
     PORTA|=0b00001010;
    (corrected due to input from pommie in other thread)
    [end of moved post]
    Yeah, i remember it demonstrated a method of using those commands to turn bits on or off in a single command without effecting the ones you don't intend to change. I can use it by copying it. But i'm not sure yet what LatA refers to.
  7. Pommie
    Mar 18, 2005
    10,008
    316
    Brisbane Australia
    If anyone wants example code that runs on a Junebug then you may find this thread interesting.
  8. Pommie
    Mar 18, 2005
    10,008
    316
    Brisbane Australia
    Triode,
    LATA is short for latch A and is a way to write to the actual latch circuitry of port A. This is needed because when you set/clear a single bit, the processor reads the whole port, modifies one bit and writes it back. So if you do PORTA|=4, it will read/modify/write (RMW) portA. If a bit on port A that was previously set high is heavily loaded it may read back as a zero and result in that being unintentionally cleared. The latch register gets around this problem by keeping (and returning) a copy of the previously written value.
    I'm pretty sure that is a confusing explanation. For a better one google, pic rmw problem.
  9. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    Yes that and one other reason. To change which bits control the LEDs ony need to change the line.
    Code (text):
    #define LED_MASK 0xC1
    You would also have to change the arrays to reflect the needed values
    Code (text):
    // LEDs on A0,A6,A7
    // LED index 0 1 2 3 4 5
    const byte valA[]={0x01,0x40,0x40,0x80,0x80,0x01};
    const byte dirA[]={0x80,0x80,0x01,0x01,0x40,0x40};
    latA is an array of bytes. The 0th element is the value you must write to LATA to get the 0th (first) charlieplexed LED to light. dirA is an array of TRISA values. The 0th element of dirA is needed to get the first charlieplexed LED to light.
    Because we are only interested in PORTA bits 0,6 and 7 we use the masking to not change the other bits (1,2,3,4,5).
    3v0
  10. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    LATAbit.LATA0 sort of thing is good to use if you only need to change one bit.
    To make your code more portable you might do
    Code (text):
    #define STATUS_LED  LATAbits.LATA0
    #define STATUS_LED_TRIS TRISAbits.TRISA0
    Then in your code write
    STATUS_LED_TRIS = 0;  // for output
    and
    STATUS_LED = 1;          // to source a LED
  11. Triode
    Triode Member
    Feb 11, 2009
    925
    22
    Bay Area
    Thanks. I think I have enough about swithing ports high and low to get my going now.
    Any good C18 tutorials on how to capture a PWM signal?
    Also, at some point I'm going to have to learn about having a pic generate multiple PWM signals for motor control, I know it can be done, but all the tutorials I see on generating PWM use wait commands in a single loop that would seem to get in the way of generating other pwm signals, or doing anything else for that matter. I know a few ways of timing several loops simultaniously on PC but they dont seem to apply on a PIC.
  12. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    We have talked about generating multiple PWM signals here several times.
    To do it in software I use a timer interrupt, 100 interrupts per period. On the 0th interrupt it turns on all outputs with a duty cycle greater than zero. For the next 99 it checks to see which if any it should turn off. On the next it turns them all back on and starts over.
    100 is handy because you can express the PWM duty cycle as percents. Choose whatever number of interrupts works for you application.
  13. be80be
    Aug 23, 2008
    4,793
    134
    morristown,tn
    That's funny looks like C18 would set it right when changing just a bit
    with just the
    Code (text):
              #define STATUS_LED PORTAbits.RA.0
    But you have to do it this way
    Code (text):
  14. Triode
    Triode Member
    Feb 11, 2009
    925
    22
    Bay Area
    Yes, I didn't mean to ask you to go over it all again. I typically read everything i can find on a subject then ask questions about what I don't get. I haven't tried out the existing information yet, which is why I said at some point I'm going to have to figure it out. But thanks for your explanation of method you use, it'll give me a good starting point. I'll probably come back with more questions about this later. I was just mentioning that I'm about to start working on learning that so if anyone knows of a good existing tutorial they can let me know about it.
    A question about the Latch command, when you change it that way, since its directly refering to the device, not the bit that controls it (as I understand it) is the bit still updated so that if you set LATAbits.LATA0 = 1 then read the status of PORTAbits.RA.0 it will also have changed? Are there any pitfalls or discrepencies here, or does it read just fine?
  15. be80be
    Aug 23, 2008
    4,793
    134
    morristown,tn
    Here you go have at the whole story in a nutshell
    • Like Like x 1
  16. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    Now that Burt has brought it up maybe we should say a word about port bit field names.
    In C18 some ports use names like
    PORTXbits.RX0
    while others will have names like
    PORTXbits.PORTX0
    If in doubt check the processor .h (ie: p18f1320.h) file to see what names are used or allowed. It helps if you understand what a union is. You can even add to or modify the definitions it you like. But I would not recommend it in most cases.
  17. Triode
    Triode Member
    Feb 11, 2009
    925
    22
    Bay Area
    The reason being that it makes your code less portable right?
  18. 3v0
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    Only in that code written to use it requires your version of the modified pxxfxxxx.h file for your code to work. For the sake of sanity do not use the original file name! It would also cause the file to be a bit harder to read because the reader would have to look to the .h file to see the nonstandard name. Neither is a big deal, but I suggest it should be done with a good reason, not because you can.
    In some cases people have rewritten the entire naming convention for embedded compilers. One example is Peter Anderson custom header files that he uses with the CCS compiler.
    Most of the time we use #define to provide alternate names for ports and bits.
  19. Triode
    Triode Member
    Feb 11, 2009
    925
    22
    Bay Area
    I was just wondering what other trouble it might cause. I woulden't change it, like you said there aren't many good reasons to do that instead of just using define. Keeping things standard is hard enough with all the versions of any given language we already have.
  20. Triode
    Triode Member
    Feb 11, 2009
    925
    22
    Bay Area
    Can anyone point me to a good demo or tutorial of using the timers and/or capture compare in C18? I've been trying to find examples and tutorials, but most of the code I can find is not meant to be an example, so it's got a lot of other stuff and not commented with a newb in mind.
  21. be80be
    Aug 23, 2008
    4,793
    134
    morristown,tn
Share This Page
