Assembly Language???
amady
Anyone has another assembly language support PIC16F84A... beside MPLAB IDE V 6.6... :lol:
could you explain your question a little bit? why do you want to use something other than the widely accepted MPLAB development package. i read somewhere that PIC can be programmed in about two dialects of assembly language; MPASM and TASM (or something like that). MPLAB contains the MPASM assembler and it works great. why would u want to migrate to another dialect of assembly. if u do want to try something else, try a high level language like C.
MPASM is the 'real' assembly for pic's, it uses all the names and terms that you find in the datasheets. It would be counterproductive to use something else.
This is because i got the problem when to generate the .hex file... the error is : succeded the 62 characters...
is it fixed ?
[quote="williB]is it fixed ?[/quote]
What do you mean?? The error still has when i'm running the MPLAB.... :cry:
The solution should be simple...
As far as I know, the path to the directory where the project is located should be less than 62 chars in length.
In my laptop and my PC at the bench I put the project file in the Desktop (WIN 98SE and WIN ME).
Hope this solve that awful problem.
Agustín Tomás
Re: The solution should be simple...
Agustín Tomás
Thank you atferrari it work's.. :eek: i was put at my C directory...
im glad things worked out for you. actually im really frustated with this type of error. the first time i started using MPASM i always got this error but then i read the error carefully and then consulted the help file. and voila!!!!!! i figured the solution. so the next time you get some error think about it a little bit and dont go for throwing out the software
OK, thank for your advice :D
Re: Hello guys i am in
techknow said:
Hey i need some help on my projects...i am trying to make a 7segment display based clock...i also have a forum www.varunulaa.com/forum in there i have posted some of my projects so ppl join they too to help.......
i dont like the color ..too dark
An help wanted
Does anyone have a simple asm code for LCD and PIC16F628 interface...cause i got some big codes..damm ..so i need an simple one which can print an "hello" word. cause i am also a biginner for microcontroller programing from asm. and i use MPLAB and ICPROG..i hope u guys will get me a good working and simple asm code for LCD intreface. any way thanks for willib
Re: An help wanted
Try reading my tutorials!.
Re: An help wanted
You can look at Nigel's website or..http://home.iae.nl/users/pouweha/lcd/lcd.shtml
and i need the PIC programmer from you! TQ
Re: Hello amady
techknow said:
Do u need the circuit diagram of my picprogrammer or the software...
all :lol:
here is ...
Amady here is the program and the circuit that i am using..it is working perfectly..so u try it and letme know...
from here you can get the software and the sys file ..if u r using windows XP or NT...If u need to view a picture of the working programmer here is the link.
