A question on counting.
gibbon_82
I have to program the 16f84 to count input pulses. depending on the amount of pulses depends on what subroutine has to be executed. Can i use the watchdog timer to count input pluses from an input pin while executing a subroutine? Or is there another way to do this?
cheers
Craig
ehh.. that is not the use of watchdog timer.
Watchdog timer is to reset the microcontroller when the operation is stuck
Timer 0 can be configured to count pulses on RA4. Check the datasheet, its all in there.
im using ra4 for my timer. im having to count the time in a subroutine at the same time as counting input pulses for an input pin. if i used this pin to increment a count somewhere else in memory, this will not carry on counting when executing a subroutine will it?
If you use timer0 as timer somewhere else, it cannot be used as pulse counter at the same time.
How fast are the pulses you're counting? How wide are the pulse widths? If they are not too fast, you can poll the RA4 pin as an ordinary I/O pin.
Use the interrupt on RB0 to set and stop counter. After that, you can re-compute the real length of your pulse, because it need 3 cycles to come to the interrupts, and 1 cycles to get back. But you know exactly when it interrupts.
If you count a variable, it can happen that the pulse is falling down as you are counting, you don't know exactly when it is. But with interrupt, you know it.
