| | #16 | |
| | #17 |
i guess i meesed this one up, your circuit is fine, i was kidding about 2 WATT output from the circuit above :-) | |
| | #18 |
audioguru, Your circuit is also better because it has an amplifier on the output to isolate the oscillator from changes on the load like someone walking in front of it and reflecting some of the radiation back to it.
| | #19 |
In my electronics career, I hardly worked with RF things. Recently, somebody on a forum posted a simple FM transmitter circuit that didn't work so I fixed and improved it in stages. My FM transmitter is just a bunch of circuits of other people that I put together.
| | #20 |
yes i have a question about the circuit "fmtransmitter3.gif", i wanted to know could i put a headphone jack input in place of the mic? because i was going to use this for my ipod inplace of buying an itrip so any help would be good thanks dan
__________________ Hmmm.....let me think......Meow! | |
| | #21 | |
The simple transmitter circuit is a lousy child's toy that would sound horrible: 1) Its RF frequency drifts all over the place if something gets near it or its antenna, and if its battery voltage drops. 2) It is mono, not stereo. 3) It doesn't have pre-emphasis (treble boost) like FM radio stations have, so it would sound muffled like an AM radio.
| | #22 |
can anyone please suggest a simple circuit for RF POWER METER for testing the oscillator output. i foun one in the site http://electronics-diy.com/tx500.php. i bulid the schematic below but it doesnt work. for the 2pF i use 1pF conected parallel. in the image of the project in the site he uses 1.8 conected in series and he 270 resistor for the emmiter insted of 1k that he has the shematic. any suggestions; The scematic below is from the site http://electronics-diy.com/tx200.php thanks in advance | |
| | #23 |
The power meter's circuit has the LED backwards. Also the transistor is not biased correctly but it might work. I don't know which 1.8, 270, 1k and emitter you are talking about.
| | #24 |
| In 1st diagrame of FM transmitter i don,t know which value of variable inductor(L1) u used?plz check this. | |
| | #25 |
You are talking about the 2watt one? Anyway it is not even 1 watt. The coil could have 5 to 6 turns on a 6 mm diameter with a 0.6 to 1 mm wire. C1 is better to be a variable one with values up to 60 pf and C2 can be a 12 or 15 pf capacitor. The coil does not need to be a variable one but an aircore. Regards P. | |
| | #26 |
gooood thank | |
| | #27 |
sorry if i'm asking a stupid question. but... would this work if i connected a headphone jack to the transmitter and put that in my ipod instead of the microphone? | |
| | #28 |
Yes but you need an attenuator (this is no problem a couple of resistors will do) and simple transmitter circuits like this give crap mono AM radio sound quality.
| | #29 |
hi thanks for reply but i have no idea plz can u send project diagram & some detail on my e mail id manishjainshah@yahoo.co.in | |
| | #30 |
can u send some theory related to it
| simple, transmitters |
