XNOR circuit - Can any one build XNOR circuit
Regards, Dana.
The circuits in post #41 are XOR not XNOR.
Their main disadvantage is they they waste more than more than normal lamp current when one one input is on, and more than twice the lamp current when both inputs are on.
The point of the post, which I should have stated, was simplicity of
logic w/o active components. And yes they are not a low power design.
And XNOR switch in one leg the R and switch.
Regards, Dana.
Okay.
It would appear that the bottom two circuits are the same except one uses four discrete diodes and the other uses a four-diode bridge.
So you don't consider diodes to be an active component?
I'm using a PNP to drive the LED, not an NPN.
Hm. You're using PNPs (2N3906) for ALL 3 transistors. Which I recognised, and tried, and decided must be a mistake as that was even less 'working' than with NPNs:
Of course, if you'd shared your LTSpice implementation, I wouldn't have had to try recreate it myself.
Hey sxy, if you find all this as confusing and unhelpful as I do, let's continue via PM and let the one-uppers play amongst themselves.
Not surprising it doesn't work since you have Q1 and Q2 backwards.
Since you were using Falstad, I didn't think you had LTspice.
Below is the LTspice file.
  • XOR XNOR 3-Transistor.asc
Circuit: * C:\Users\ms20b\Documents\XOR XNOR 3-Transistor.asc
Error on line 8 : d1 p002 n003 ledred
Unable to find definition of model "ledred"
Direct Newton iteration for .op point succeeded.
Date: Sun Aug 22 04:17:02 2021
Total elapsed time: 12.015 seconds.
tnom = 27
temp = 27
method = modified trap
totiter = 3680
traniter = 3667
tranpoints = 1640
accept = 1478
rejected = 162
matrix size = 20
fillins = 2
solver = Normal
Matrix Compiler1: 1.36 KB object code size 0.4/0.3/[0.3]
Matrix Compiler2: off [0.2]/0.5/1.1
Just use an LED model that you have in your LTspice library.
I have an LTSpice library?
That's why I used Falstad to demo for sxy; no dependancies. (Nor steep learning curve; nor stupid UI;...)
(+ visual indication of current flows and rates; mouse over scoping;...)
sxy,
See here for a working Falstad implementation of Crutschow's XOR/XNOR circuits. Note that the XNOR version is the XOR + a NOT gate to invert the output.
Okay.
Regards, Dana.
Definition(s) -
https://www.arrow.com/en/research-and-events/articles/active-vs-passive-components-in-electronics
That states a diode is an active device.
So take your pick.
As you can see there is no biblical definition of active versus passive.
But that guys def leaves one to wonder why he considered diodes as active
In a nutshell, active components can, generally speaking, inject power into a circuit and are capable of electrically controlling and amplifying the flow of electrical current, whereas passive components cannot.
Of course we can spend a year or two debating what applies to what in the above def.....UGH.
Here they are considered passive, but then broadly classify tube's as active, would that
also be true of tubes with no elements, no connections. Silly.
But then -
Lets debate this until neither of us is breathing anymore.
Regards, Dana.
Naw, I'm good.
I don't have enough breaths left anymore to use them for that.
