Angry Badger
My mistake I think.
#ifndef __HD44780_H
#define __HD44780_H
// Library for control LCD HD44780 *
// Mode Control 4 bits *
// By Hector *
// http://www.youtube.com/user/Hector8389 *
//#include <p18f452.h> // Select your MCU
#include <p18f2420.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <delays.h>
// Configure your MCU. Any mode //
// Pin Set digital mode. your code //
#define LCD_RD7 LATBbits.LATB0 // D7
#define TRIS_RD7 TRISBbits.TRISB0
#define LCD_RD6 LATBbits.LATB1 // D6
#define TRIS_RD6 TRISBbits.TRISB1
#define LCD_RD5 LATBbits.LATB2 // D5
#define TRIS_RD5 TRISBbits.TRISB2
#define LCD_RD4 LATBbits.LATB3 // D4
#define TRIS_RD4 TRISBbits.TRISB3
#define LCD_EN LATBbits.LATB4 // EN
#define TRIS_EN TRISBbits.TRISB4
#define LCD_RS LATBbits.LATB5 // RS
#define TRIS_RS TRISBbits.TRISB5
// Available Lcd Commands //
#define LCD_FIRST_ROW (128)
#define LCD_SECOND_ROW (192)
#define LCD_THIRD_ROW 148
#define LCD_FOURTH_ROW 212
#define LCD_CLEAR 1
#define LCD_RETURN_HOME 2
#define LCD_CURSOR_OFF 12
#define LCD_UNDERLINE_ON 14
#define LCD_BLINK_CURSOR_ON 15
#define LCD_MOVE_CURSOR_LEFT 16
#define LCD_MOVE_CURSOR_RIGHT 20
#define LCD_TURN_OFF 0
#define LCD_TURN_ON 8
#define LCD_SHIFT_LEFT 24
#define LCD_SHIFT_RIGHT 28
void Lcd_Init(void);
//void Lcd_Out(unsigned char y, unsigned char x, const rom char *buffer);
void Lcd_Out(unsigned char y, unsigned char x, const char *buffer);
void Lcd_Out2(unsigned char y, unsigned char x, char *buffer);
void Lcd_Chr_CP(char data);
void Lcd_Cmd(unsigned char Cmd);
void Delay_5us(void);
void Delay_5500us(void);
// Set delays, based on the //
// frequency of a XTAL. //
void Delay_5us(void){
// Delay of 5us
// Cycles = (5us * 20MHz) / 4
// Cycles = 25
// Put 25 more
Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop(); Nop();
void Delay_5500us(void){
// Delay of 5.5ms
// Cycles = (5.5ms * 20MHz) / 4
// Cycles = 27,500 = 28,000
Delay1KTCYx(28);
void Lcd_Init(void){
unsigned char data;
TRIS_RD7 = 0; TRIS_RD6 = 0; TRIS_RD5 = 0; TRIS_RD4 = 0; TRIS_EN = 0; TRIS_RS = 0;
LCD_RD7 = 0; LCD_RD6 = 0; LCD_RD5 = 0; LCD_RD4 = 0; LCD_EN = 0; LCD_RS = 0;
// 167mS
Delay_5500us(); Delay_5500us(); Delay_5500us();
for(data = 1; data < 4; data ++)
LCD_RD7 = 0; LCD_RD6 = 0; LCD_RD5 = 1; LCD_RD4 = 1; LCD_EN = 0; LCD_RS = 0;
LCD_RD7 = 0; LCD_RD6 = 0; LCD_RD5 = 1; LCD_RD4 = 1; LCD_EN = 1; LCD_RS = 0;
Delay_5us();
Delay_5500us();
LCD_RD7 = 0; LCD_RD6 = 0; LCD_RD5 = 1; LCD_RD4 = 0; LCD_EN = 0; LCD_RS = 0;
LCD_RD7 = 0; LCD_RD6 = 0; LCD_RD5 = 1; LCD_RD4 = 0; LCD_EN = 1; LCD_RS = 0;
Delay_5us();
Delay_5500us();
data = 40; Lcd_Cmd(data);
data = 16; Lcd_Cmd(data);
data = 1; Lcd_Cmd(data);
data = 15; Lcd_Cmd(data);
unsigned char data;
switch (y)
case 1:
data = 128 + x;
break;
case 2:
data = 192 + x;
break;
case 3:
data = 148 + x;
break;
case 4:
data = 212 + x;
break;
default:
break;
Lcd_Cmd(data);
while(*buffer) // Write data to LCD up to null
Lcd_Chr_CP(*buffer);
buffer++; // Increment buffer
return;
unsigned char data;
switch (y)
case 1:
data = 128 + x;
break;
case 2:
data = 192 + x;
break;
case 3:
data = 148 + x;
break;
case 4:
data = 212 + x;
break;
default:
break;
Lcd_Cmd(data);
return;
void Lcd_Chr_CP(char data){
LCD_EN = 0; LCD_RS = 1;
LCD_RD7 = (data & 0b10000000)>>7; LCD_RD6 = (data & 0b01000000)>>6;
LCD_RD5 = (data & 0b00100000)>>5; LCD_RD4 = (data & 0b00010000)>>4;
LCD_EN = 1; Delay_5us(); LCD_EN = 0;
LCD_RD7 = (data & 0b00001000)>>3; LCD_RD6 = (data & 0b00000100)>>2;
LCD_RD5 = (data & 0b00000010)>>1; LCD_RD4 = (data & 0b00000001);
Delay_5us(); Delay_5500us();
void Lcd_Cmd(unsigned char Cmd){
unsigned char data;
data = Cmd;
Delay_5500us();//Delay_5us();
#endif
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "hd44780.h"
//#include "my_delays.h"
#include <delays.h>
#include <xc.h>
//THESE ARE CONFIG WORDS FOR A 2420!
#pragma config CONFIG1H = 0X08;
#pragma config CONFIG2L = 0X19;
#pragma config CONFIG2H = 0X1E;
#pragma config CONFIG3H = 0X01; // MCLRE ON = 0x81, OFF = 0x01
#pragma config CONFIG4L = 0X80;
#define _XTAL_FREQ (4000000)
void main(void)
OSCCON = 0b01100010; // Fosc = 4MHz (Inst. clk = 1MHz)
ADCON1 = 0xF; // No analog, all digital i/o
TRISA = 0x00;
TRISB = 0x0;
TRISC = 0x0;
LATB = 0x0;
Lcd_Init();
Lcd_Cmd(LCD_CLEAR);
Lcd_Cmd(LCD_CURSOR_OFF);
/******************** ADC Initilization ***********************************/
//ADCON1 = 0x80; // Configure analog inputs and Vref
//TRISA = 0xFF;
//Delay_ms(100);
__delay_ms(100);
while(1)
Lcd_Out(1, 1, "Free download");
//Delay_ms(500);
while(1);
Even Changing Port direction and adding 0x28 inplace of lcd_type does not makes it work
#include <xc.h>
#include "My_xlcd.h"
// CONFIG1H
#pragma config OSC = HS // Oscillator Selection bits (HS oscillator)
#pragma config OSCS = OFF // Oscillator System Clock Switch Enable bit (Oscillator system clock switch option is disabled (main oscillator is source))
// CONFIG2L
#pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = ON // Brown-out Reset Enable bit (Brown-out Reset enabled)
#pragma config BORV = 20 // Brown-out Reset Voltage bits (VBOR set to 2.0V)
// CONFIG2H
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 128 // Watchdog Timer Postscale Select bits (1:128)
// CONFIG3H
#pragma config CCP2MUX = ON // CCP2 Mux bit (CCP2 input/output is multiplexed with RC1)
// CONFIG4L
#pragma config STVR = ON // Stack Full/Underflow Reset Enable bit (Stack Full/Underflow will cause RESET)
#pragma config LVP = ON // Low Voltage ICSP Enable bit (Low Voltage ICSP enabled)
// CONFIG5L
#pragma config CP0 = OFF // Code Protection bit (Block 0 (000200-001FFFh) not code protected)
#pragma config CP1 = OFF // Code Protection bit (Block 1 (002000-003FFFh) not code protected)
#pragma config CP2 = OFF // Code Protection bit (Block 2 (004000-005FFFh) not code protected)
#pragma config CP3 = OFF // Code Protection bit (Block 3 (006000-007FFFh) not code protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot Block (000000-0001FFh) not code protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM not code protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection bit (Block 0 (000200-001FFFh) not write protected)
#pragma config WRT1 = OFF // Write Protection bit (Block 1 (002000-003FFFh) not write protected)
#pragma config WRT2 = OFF // Write Protection bit (Block 2 (004000-005FFFh) not write protected)
#pragma config WRT3 = OFF // Write Protection bit (Block 3 (006000-007FFFh) not write protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block (000000-0001FFh) not write protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000200-001FFFh) not protected from Table Reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (002000-003FFFh) not protected from Table Reads executed in other blocks)
#pragma config EBTR2 = OFF // Table Read Protection bit (Block 2 (004000-005FFFh) not protected from Table Reads executed in other blocks)
#pragma config EBTR3 = OFF // Table Read Protection bit (Block 3 (006000-007FFFh) not protected from Table Reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot Block (000000-0001FFh) not protected from Table Reads executed in other blocks)
#define _XTAL_FREQ (8000000) /* Not using xtal, only to make delays work as
it won't compile without this */
void DelayFor18TCY(void);
void DelayPORXLCD(void);
void DelayXLCD(void);
void main (void)
TRISA = 0x00;
TRISB = 0x0;
TRISC = 0x0;
LATB = 0x0;
while(1)
OpenXLCD(0x2C);
while(BusyXLCD());
WriteCmdXLCD(SHIFT_DISP_LEFT);
while(BusyXLCD());
WriteDataXLCD('A');
while(BusyXLCD());
WriteDataXLCD('t');
while(BusyXLCD());
WriteDataXLCD(' ');
while(BusyXLCD());
putrsXLCD( "last! XLCD," );
while(BusyXLCD());
WriteCmdXLCD(0xC0);
while(BusyXLCD());
putrsXLCD( "thanks Ian" );
while(BusyXLCD());
while(1);
__delay_us(18);
__delay_ms(15);
__delay_ms(5);
// LCD module connections
sbit LCD_RS at RB5_bit;
sbit LCD_EN at RB4_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB5_bit;
sbit LCD_EN_Direction at TRISB4_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
const char txt1[] = "A";
const char txt2[] = "B";
const char txt3[] = "C";
const char txt4[] = "D";
char i; // Loop variable
char array[6];
void Move_Delay() { // Function used for text moving
Delay_ms(500); // You can change the moving speed here
void main() {
PORTD = 0x00;
TRISD = 0x00;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
while(1)
Lcd_Out(1,1,"EEPROM Test");
PORTD = ~PORTD;
Delay_ms(2000);
16X2 ALPHANEUMERIC LCD INTERFACING LIBRARY FOR PIC 18F MCUS
Easy to use library for interfacing 16x2 lcd in 4 bit mode.
MCU: PIC18FXXXX Series from Microchip.
Compiler: HI-TECH C Compiler for PIC18 MCUs (http://www.htsoft.com/)
Copyrights 2008-2009 Avinash Gupta
eXtreme Electronics, India
For More Info visit
http://www.eXtremeElectronics.co.in
Mail: [email protected]
#include "lcd.h"
#define LCD_DATA_LAT LAT(LCD_DATA)
#define LCD_E_LAT LAT(LCD_E)
#define LCD_RS_LAT LAT(LCD_RS)
#define LCD_RW_LAT LAT(LCD_RW)
#define LCD_DATA_TRIS TRIS(LCD_DATA)
#define LCD_E_TRIS TRIS(LCD_E)
#define LCD_RS_TRIS TRIS(LCD_RS)
#define LCD_RW_TRIS TRIS(LCD_RW)
#define LCD_DATA_PORT PORT(LCD_DATA)
#define SET_E() (LCD_E_LAT|=(1<<LCD_E_POS))
#define SET_RS() (LCD_RS_LAT|=(1<<LCD_RS_POS))
#define SET_RW() (LCD_RW_LAT|=(1<<LCD_RW_POS))
#define CLEAR_E() (LCD_E_LAT&=(~(1<<LCD_E_POS)))
#define CLEAR_RS() (LCD_RS_LAT&=(~(1<<LCD_RS_POS)))
#define CLEAR_RW() (LCD_RW_LAT&=(~(1<<LCD_RW_POS)))
void LCDByte(uint8_t c,uint8_t isdata)
//Sends a byte to the LCD in 4bit mode
//cmd=0 for data
//cmd=1 for command
//NOTE: THIS FUNCTION RETURS ONLY WHEN LCD HAS PROCESSED THE COMMAND
uint8_t hn,ln; //Nibbles
uint8_t temp;
hn=c>>4;
ln=(c & 0x0F);
if(isdata==0)
CLEAR_RS();
else
SET_RS();
__delay_us(0.500); //tAS
SET_E();
//Send high nibble
temp=(LCD_DATA_LAT & 0XF0)|(hn);
LCD_DATA_LAT=temp;
__delay_us(1); //tEH
//Now data lines are stable pull E low for transmission
CLEAR_E();
__delay_us(1);
//Send the lower nibble
SET_E();
temp=(LCD_DATA_LAT & 0XF0)|(ln);
LCD_DATA_LAT=temp;
//SEND
CLEAR_E();
__delay_us(1); //tEL
LCDBusyLoop();
void LCDBusyLoop()
//This function waits till lcd is BUSY
uint8_t busy,status=0x00,temp;
//Change Port to input type because we are reading data
LCD_DATA_TRIS|=0x0F;
//change LCD mode
SET_RW(); //Read mode
CLEAR_RS(); //Read status
//Let the RW/RS lines stabilize
__delay_us(0.5); //tAS
do
SET_E();
//Wait tDA for data to become available
__delay_us(0.5);
status=LCD_DATA_PORT;
status=status<<4;
__delay_us(0.5);
//Pull E low
CLEAR_E();
SET_E();
__delay_us(0.5);
temp=LCD_DATA_PORT;
temp&=0x0F;
status=status|temp;
busy=status & 0b10000000;
__delay_us(0.5);
CLEAR_E();
}while(busy);
CLEAR_RW(); //write mode
//Change Port to output
LCD_DATA_TRIS&=0xF0;
void LCDInit(uint8_t style)
This function Initializes the lcd module
must be called before calling lcd related functions
Arguments:
style = LS_BLINK,LS_ULINE(can be "OR"ed for combination)
LS_BLINK :The cursor is blinking type
LS_ULINE :Cursor is "underline" type else "block" type
//After power on Wait for LCD to Initialize
__delay_ms(30);
//Set IO Ports
LCD_DATA_TRIS&=(0xF0);
LCD_E_TRIS&=(~(1<<LCD_E_POS));
LCD_RS_TRIS&=(~(1<<LCD_RS_POS));
LCD_RW_TRIS&=(~(1<<LCD_RW_POS));
LCD_DATA_LAT&=0XF0;
CLEAR_E();
CLEAR_RW();
CLEAR_RS();
//Set 4-bit mode
__delay_us(0.3); //tAS
SET_E();
LCD_DATA_LAT|=(0b00000010); //[B] To transfer 0b00100000 i was using LCD_DATA_PORT|=0b00100000
__delay_us(1);
CLEAR_E();
__delay_us(1);
//Wait for LCD to execute the Functionset Command
LCDBusyLoop(); //[B] Forgot this delay
//Now the LCD is in 4-bit mode
LCDCmd(0b00001100|style); //Display On
LCDCmd(0b00101000); //function set 4-bit,2 line 5x7 dot format
void LCDWriteString(const char *msg)
This function Writes a given string to lcd at the current cursor
location.
Arguments:
msg: a null terminated string to print
while(*msg!='\0')
LCDData(*msg);
msg++;
void LCDWriteInt(int val,unsigned int field_length)
This function writes a integer type value to LCD module
Arguments:
1)int val : Value to print
2)unsigned int field_length :total length of field in which the value is printed
must be between 1-5 if it is -1 the field length is no of digits in the val
char str[5]={0,0,0,0,0};
int i=4,j=0;
while(val)
str[i]=val%10;
val=val/10;
i--;
if(field_length==-1)
while(str[j]==0) j++;
else
j=5-field_length;
if(val<0) LCDData('-');
for(i=j;i<5;i++)
LCDData(48+str[i]);
void LCDGotoXY(uint8_t x,uint8_t y)
if(x<40)
if(y) x|=0b01000000;
x|=0b10000000;
LCDCmd(x);
16X2 ALPHANEUMERIC LCD INTERFACING LIBRARY TEST PROGRAM
A testing program for our LCD library.
For More Info visit
#include <xc.h>
#include "lcd.h"
// CONFIG1H
// CONFIG2L
// CONFIG2H
// CONFIG3H
// CONFIG4L
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
//Simple Delay Routine
void Wait(unsigned int delay)
for(;delay;delay--)
__delay_us(100);
void main()
//Let the Module start up
Wait(100);
PORTD = 0x00;
TRISD = 0x00;
//Initialize the LCD Module
LCDInit(LS_BLINK);
//Clear the Module
LCDClear();
//Write a string at current cursor pos
LCDWriteString("**** Yeh!!");
Wait(20000);
//Now Clear the display
LCDClear();
LCDWriteString("God Bless all !!");
//Goto POS (X=0,Y=1 i.e. Line 2)
//And Write a string
LCDWriteStringXY(5,1,"<**************>");
Wait(20000);
//Write Some Numbers
for(char i=0;i<100;i++)
LCDClear();
LCDWriteInt(i,3);
Wait(3000);
LCDClear();
LCDWriteString(" The End ");
//Loop Forever
while(1)
PORTD = ~PORTD;
#define _XTAL_FREQ 8000000UL
#include "myutils.h"
#ifndef _LCD_H
#define _LCD_H
typedef unsigned char uint8_t;
/*_________________________________________________________________________________________*/
LCD CONNECTIONS
#define LCD_DATA B //Port PD0-PD3 are connected to D4-D7
#define LCD_E B //Enable/strobe signal
#define LCD_E_POS 4 //Position of enable in above port
#define LCD_RS B
#define LCD_RS_POS 5
#define LCD_RW B
#define LCD_RW_POS 6
#define LS_BLINK 0B00000001
#define LS_ULINE 0B00000010
F U N C T I O N S
void LCDInit(uint8_t style);
void LCDWriteString(const char *msg);
void LCDWriteInt(int val,unsigned int field_length);
void LCDGotoXY(uint8_t x,uint8_t y);
//Low level
void LCDByte(uint8_t,uint8_t);
#define LCDCmd(c) (LCDByte(c,0))
#define LCDData(d) (LCDByte(d,1))
void LCDBusyLoop();
F U N C T I O N S E N D
M A C R O S
#define LCDClear() LCDCmd(0b00000001)
#define LCDHome() LCDCmd(0b00000010)
#define LCDWriteStringXY(x,y,msg) {\
LCDGotoXY(x,y);\
LCDWriteString(msg);\
#define LCDWriteIntXY(x,y,val,fl) {\
LCDGotoXY(x,y);\
LCDWriteInt(val,fl);\
#endif
#include <p18f4520.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <delays.h>
#include <xc.h>
//THESE ARE CONFIG WORDS FOR A 4520!
#define _XTAL_FREQ (4000000) // SET THIS TO SUIT YOUR FREQUENCY
void main(void)
TRISA = 0x00;
TRISB = 0x0;
TRISC = 0x0;
LATB = 0x0;
Lcd_Init();
Lcd_Cmd(LCD_CLEAR);
while(1)
//__delay_ms(100);
Lcd_Out(1, 1, "Hi Afran");
while(1);
Oh dear... You have moved onto the XC8 compiler.... The code posted was originally targeted to the C18..
I have given you C18 code..... I'll have a go at it tonight... I'll post a library that works with XC8...
