More fun with ws2812 this time XC8 and CLC
I have converted yours an I get outputs... The CLC has to be set up correctly as the PPS has to redirect them.
I have to work out the final output with the CLC SD0 and the SCK and SD0... I get a completely wrong stream out.
If I want red blue green I get white blue and blah kinda rust!!!
Here is the changes I made...
The issue you were having was just T2 control... If you are real hardware you will have better luck as the software I have here... Waaaaay too slow with 12 RGB units.. ( I'll change it to three to get some speed up.)
 * @file main.c
 * @brief Final WS2812 LED Driver using CLC, SPI, and TMR on PIC18F26Q10
 * @author Gemini (Corrected Version)
 * @date July 14, 2025
 * @details
 * This program drives WS2812 LEDs using a robust, hardware-only method.
 * This version uses the CLC as a 2-to-1 Multiplexer and standard CCP/MSSP
 * peripherals to ensure maximum compiler compatibility.
 * Hardware Logic:
 * 1. TMR2: Sets the bit period to 1.25us (800 kHz).
 * 2. CCP2 (in PWM mode): Generates the short high pulse for a '0' bit (~437ns).
 * 3. SPI1 (MSSP1): The SPI Clock (SCK) provides the long high pulse for a '1' bit.
 * The SPI Data (SDO) acts as the selector for the MUX.
 * 4. CLC1 (AND-OR MUX):
 * - Logic: (CCP2_OUT & !SDO) | (SCK & SDO)
 * - If SDO is 0, it selects the CCP2 pulse.
 * - If SDO is 1, it selects the SCK pulse.
 * 5. PPS: Routes the final CLC1 output to a physical pin (RC2).
// CONFIGURATION BITS
#pragma config FEXTOSC = OFF
#pragma config RSTOSC = HFINTOSC_64MHZ // IMPORTANT: 64MHz Clock is required
#pragma config CLKOUTEN = OFF
#pragma config CSWEN = ON
#pragma config FCMEN = ON
#pragma config MCLRE = INTMCLR
#pragma config PWRTE = ON
#pragma config BOREN = SBORDIS
#pragma config BORV = VBOR_190
#pragma config ZCD = OFF
#pragma config PPS1WAY = ON
#pragma config STVREN = ON
#pragma config WDTE = OFF
// INCLUDES
#include <xc.h>
#include <stdint.h>
#include <string.h>
// DEFINES
#define _XTAL_FREQ 64000000UL
#define NUM_LEDS 12 // Define how many LEDs are in your strip
#define DIAGNOSTIC_LED_LAT LATCbits.LATC0
// Buffer to hold the GRB color data for each LED
static uint8_t led_color_data[NUM_LEDS * 3];
// PROTOTYPES
void SYSTEM_Initialize(void);
void PINS_Initialize(void);
void TMR2_Initialize(void);
void CCP2_Initialize(void);
void SPI_Initialize(void);
void CLC_Initialize(void);
void WS2812_SetPixelColor(uint16_t pixel, uint8_t red, uint8_t green, uint8_t blue);
void WS2812_Show(void);
// DRIVER FUNCTIONS
void WS2812_SetPixelColor(uint16_t pixel, uint8_t red, uint8_t green, uint8_t blue) {
    if (pixel < NUM_LEDS) {
        uint16_t index = pixel * 3;
        led_color_data[index + 0] = green;
        led_color_data[index + 1] = red;
        led_color_data[index + 2] = blue;
void WS2812_Show(void) {
    for(uint16_t i = 0; i < sizeof(led_color_data); i++) {
        SSP1IF = 0;
        SSP1BUF = led_color_data[i];
        while(!SSP1IF); // Wait for transmission to complete
    __delay_us(100); // Latch pulse
// INITIALIZATION ROUTINES
void SYSTEM_Initialize(void) {
    OSCCON1 = 0x60;
    OSCFRQ = 0x08;
    PINS_Initialize();
    TMR2_Initialize();
    CCP2_Initialize(); // Use CCP2 instead of PWM6
    SPI_Initialize();
    CLC_Initialize();
void PINS_Initialize(void) {
    ANSELC = 0x00;
    TRISC = 0x00; // Set all PORTC pins as output for simplicity
    LATC = 0x00;  // Start with all pins low
    PPSLOCK = 0x55;
    PPSLOCK = 0xAA;
    PPSLOCK = 0x00; // Unlock PPS
    RC1PPS = 0x10; // SDO1 -> RC1
    RC3PPS = 0x0F; // SCK1 -> RC3
    RC2PPS = 0x18; // CLC1OUT -> RC2
    PPSLOCK = 0x55;
    PPSLOCK = 0xAA;
    PPSLOCK = 0x01; // Lock PPS
void TMR2_Initialize(void) {
    T2PR = 19; // Period = (19+1) * 4 * (1/64MHz) = 1.25us => 800kHz
    T2CLKCON = 3;
    T2HLT = 3;
    T2CON = 0b10000000;
void CCP2_Initialize(void) {
    // FIX: Use the correct register name as suggested by the compiler.
    CCPTMRSbits.C2TSEL = 0b01;
    // Configure CCP2 for PWM mode
    // FIX: Removed reference to non-existent DC2B bit. The lower two bits
    // of the duty cycle are set to 0 by this single assignment.
    CCP2CON = 0b10001100; // Enable PWM, P2M<1:0> = 00 for single output
    // Set Duty Cycle for the '0' bit high time (~437.5ns)
    // Duty cycle value is 10 bits. (437.5ns / 62.5ns) = 7
    CCPR2L = 7;
void SPI_Initialize(void) {
    SSP1ADD = 0; // Not used when clock is TMR2
    SSP1STAT = 0b01000000; // CKE=1
    // SSPM<3:0> = 1011 -> Master mode, clock = TMR2_match/2
    SSP1CON1 = 0b00100011; // SSPEN=1, Set clock source to TMR2
void CLC_Initialize(void) {
    // Configure CLC1 as a MUX: (CCP2_OUT & !SDO) | (SCK & SDO)
    CLC1SEL0 = 0x19;       // Input 1: CCP2_OUT
    CLC1SEL1 = 0x2D;       // Input 2: SDO1
    CLC1SEL2 = 0x2E;       // Input 3: SCK1
    CLC1SEL3 = 0x2D;       // Input 4: SDO1
    CLC1GLS0 = 0b00000010; // Gate 1 logic = S1
    CLC1GLS1 = 0b00001000; // Gate 2 logic = S2
    CLC1GLS2 = 0b00100000; // Gate 3 logic = S3
    CLC1GLS3 = 0b10000000; // Gate 4 logic = S4
    CLC1POL = 0b00000010; // Invert Gate 2 output to get !SDO
    CLC1CON = 0b10000100;  // Enable, AND-OR mode
// MAIN APPLICATION
void main(void) {
    SYSTEM_Initialize();
    __delay_ms(10);
    memset(led_color_data, 0, sizeof(led_color_data));
    WS2812_Show();
    __delay_ms(10);
    uint8_t led_position = 0;
    while (1) {
        DIAGNOSTIC_LED_LAT = ~DIAGNOSTIC_LED_LAT;
        for (uint8_t i = 0; i < NUM_LEDS; i++) {
            if (i == led_position) {
                WS2812_SetPixelColor(i, 0, 150, 0); // Dim Green
            } else {
                WS2812_SetPixelColor(i, 150, 0, 00);
        WS2812_Show();
        led_position++;
        if (led_position >= NUM_LEDS) {
            led_position = 0;
        __delay_ms(100);
I have some very good bit bang code that why I’m using 64 mhz clock but 20 worked good
Timing the trick to get colors right my code it made only white I got new logic tool to find the problem I’ll try out your code Ian thanks
I ran this by AI the color problem is timing and from what it said spi is to fast so the high for a 1 is not solid its bunch
of fast toggles
Both the CCP and SSP are using TR2.. TM2 is set up to 1.25us
That is 20 cycles at 64Mhz ( remember the TOSC is 16Mhz) But T2 PR is set to 19 ( which is correct )
The CCPRL is set to 7 ( based on 30% of 19 ) but the timing is way off. I'm getting colours but not the correct ones.
I was getting blips not square wave. I wonder if this PIC has slew control?
But going back to my first statement, the timing calculations are set up good.
But!!! The T2 input to the SPI is twice that ie... TMR2/2 in the datasheet. so maybe we need to half everything??
That is 10 cycles at 64Mhz ( remember the TOSC is 16Mhz) But T2 PR is set to 19 ( which is correct )
The CCPRL is set to 7 ( based on 30% of 19 ) so the timing is way off. I'm getting colours but not the correct ones.
Most modernish PIC's have skew control, and it's ON by default - if you're running fast SPI this messes it up, and you need to set it to OFF for the SPI pins.
Hi Nigel... the SPI isn't the issue.. The CLCout on RC2 is the issue..
The SPI is internally directed to the CLC inputs along with the CCP signal.. The CLC is producing the desired waveform
Same thing, turn skew OFF on RC2 :D - assuming the processor in question has skew control?, the skew is an I/O pin function, not a peripheral one.
The problem with Ian code changes is it’s not getting the 1 and 0 right I think I should get each part working the AI changed code to a bit bang code it’s not outputting voltage high enough but same hardware with Ian code lights up I’m try Nigel’s code this weekend
There is something not right about the SPI... In your code there is a test point on RC1 and RC3 but nothing is present. I cant get the spi to run at the speed required.
A quick T2PR test is " 1/ time/2 = frequency" Ergo.. 1/ 1.25us / 2 = 400khz not 800khz as in the code.
to get 800Khz T2PR needs to be 1 / 0.625 / 2 like I said in one of my last posts, twice as fast..
I got a new programmer the pickit 3 don't like the 18f26q10 Im check the period one was dead on 800 khz
This is way better the pickit5 works very good The period is way off 810ns 1.23 mhz
I've stuck my scope on a working example I've got here, using a 16F18446 - although I'm finding it hard to sync to - I did eventually manage to get a stored frame, and the pulses are about 300nS, and the gaps just under 1uS. So 800nS and 350nS sounds about right.
Unfortunately, I can't seem to find the source code for it?, although it's certainly based on the example I posted above.
Interestingly, I've got two three pin connectors hung off it, from two different I/O pins, one feeding an 8x8 matrix, the other feeding a 16 pixel ring. I'm presuming I've just set the PPS to output the same signal on two I/O pins?.
The problem I’m seeing is the OSC is not running at 64 mhz clock I using a 200 mhz logic tool to see output
Modern PIC's have such a bewildering array of configuration options that's it's difficult to get them set correctly, I find it's worth using the MCC to set the options, then cut and paste the section of code.
