Worldwide lighting made 20% more efficienct.
Flyback
Hello
....this company has the answer to make worldwide lighting 20% more efficient.
Why?...well, because the PFC stage is centralised to a power hub, and then the LED lamps draw from it. The central PFC stage is 99.5% PFC, far better than today's units where each LED lamp has to have its own PFC, being only about 85 % PFC.
This hugh PFC improvement will mean huge savings as there will be much less i^2R heating in the supply system cables.
So why is the world not asking for an isotera system?
How much is it? Couldn't find pricing.
Actually I could find very little about the technology on their website, Google revealed even less. Not sure how efficient a contact-less coupling would be or why it's even necessary in a light fixture.
I think the problem with LED lighting in general is initial cost and light output. LEDs are about 5X more efficient than incandescent and they still aren't setting the world on fire. So another few percent doesn't mean much. CFLs offer similar savings and fit in existing fixtures for lower initial cost.
the coupling is very high 90's efficient.
Lighting is 20% of the worlds energy cosumption...more than computing.
The PFC needs to be centralised into a highly efficient hub, where it can be made 99% PFC....that much we agree i am sure(?).....then you either have DC coming off that or high frequency AC.
The problem with DC is that you need it to be high dc voltage to keep current down....but then you get too much contact sparking when you hot-plug lamps in and out.
I dont work for them but my organisation is considering installing from them, and we have been offered a grant to do so. I can see this massive efficiency saving due to the centralised PFC, and i am thinking, surely its gotta be the way?
Fortunately they typical residential customer is not charged for poor power factor so regardless of having PFC of .2 or 1 the customer does not pay any difference in cost.
Now that said going from a typical 85% PF to a 99% PF on a lighting system that uses 1/5 the power again doesn't add up to squat in I/R2 losses.
Try the math yourself.
Say I have a large incandescent lighting load in my home that takes 2400 watts on a 120 VAC service. Thats 20 amps at a PF of 1 being it's pure resistive load.
Now I change that out oto LED that uses 1/5th the power but at a PF of .85. So from that I am now drawing roughly ~4.7 amps.
On my first incandescent lighting system I had .1 ohms of line resistance in the lighting circuit leaving me with a 2 volt at 20 amps load loss or 40 watts line loses.
Now on the LED system I still have the .1 ohm line resistance which at 4.7 amps gives me a .47 volt at 4.7 amp loss or about 2.3 watts loss.
Now going with your .99 PF lighting system over my.85 PF system you now drop my losses to .4 volts at 4 amps or 1.6 watts saving me a whole .7 watts per hour.
Given my present cost of 8 cents a KWH your LED system would take ~1429 hours (59.5 days) of leaving all my lighting on to save me one KWH. Taking that out a non stop running for a full year 24 hours a day your system would save me about 50 cents. :rolleyes:
Somehow at a savings of at best of 50 cents a year for 24/7/365 running I really don't see your .99 PFC being worth anything to me savings wise. :(
If you are really looking for good quality lighting systems with high efficiency and very high average service life with color and light characteristics far superior to LED Induction lighting in the way to go! :D
That's complete B.S.
Lighting makes a very small fraction of domestic energy use, much less than 5% and in areas where people have a lot of heating might be less than 2%.
And lighting is much lower % of electricity in industry than in domestic.
And that's just in actual electricity "energy", if you include all the other energy use by the world (ie oil) then electric lighting is only a tiny fraction of 1% of the world's total "energy consumption".
Lighting makes a very small fraction of domestic energy use, much less than 5% and in areas where people have a lot of heating might be less than 2%...
Well, not in the US
According to this the losses in the power grid are typically 6-8% of the power consumed. Assuming those loses are mainly due to the resistance in the grid, the power factor only affects that 6-8% loss due to the increased current cause by the PF. For example a 0.85 PF would mean there is a 0.15 increase in the total current from the device. This increases the resistive grid loss by the square of the current increase or 1.15^2 - 1.0 = .32. Thus the increase in grid loss would be 0.32 * 6-8% = 1.94-2.58%. So the best you could do by increasing the PF form 0.85 to 1.0 would be to reduce the total power by 1.94-2.58%, significant but not a large factor.
..i am talking about the losses in the supply system , before the electricity even gets to the house or building..theres miles of cable out there.
centralised pfc (as in isotera power hub) = better overall pfc for the lighting = less current in the supply cables from the power station
Okay I've asked you before, where are you getting these efficiency numbers from? I've checked isotera's web site and the few PDFs and I'm not getting any real data. I couldn't find the 99.5% number you quoted and that's only PFC (I found PFC 95.5% in one of the data sheets) but that's not the overall efficiency of the device. LEDs are excellent but they do get hot and heat is wasted energy.
Those inductive couplings are either magical or inefficient. I can't find any info on the couplers, I can't even find isotera's Patent.
The utility supply side has its power factor constantly monitored and adjusted by the power companies themselves. If they wanted a higher power factor than they normally run at they can easily adjust their system to compensate for it.
Now more importantly apparently you do not understand that to get the power to move through the system there has to be a some amount of PF offset or they system will not work which is why they try to keep it in a range of roughly .9 - .95 as a whole on their side of the meter.
Personally I have no want need or concern in spending more of my money to solve a problem that does not exist in a system I have no say over in how it's operated.
Wow. Thanks for the information I'm really surprised at 13% of domestic electricity used for lighting!!
From those stats it looks like Americans have LOTS of lighting, don't cook much, and use natural gas etc for central heating and hot water instead of electric heating.
Anyway even if their figures are correct it is 12% of total electricity used for lighting, not 20% of "total energy consumption", which is a massive difference.
I presume most % went to the factory motors and whatnot?
