Wireless I2C
adamthole
I am interested in connecting an I2C master to an I2C slave through a wireless link. When I search for Wireless I2C on Google, I get results that make it seem there is a way to do this, but no real results.
Any ideas or help is appreciated. It is a fairly tough problem (to me anyway) because the data line on I2C is bi-directional.
I2C is designed to connect chips on the same PCB - doing it wirelessly would be completely pointless, there are MUCH better ways to connect devices wirelessly.
Perhaps if you tell us EXACTLY what you're wanting to do?, we can make suggestions.
The above transceiver has heaps of features;
  • True single chip FSK transceiver 433MHz
  • Few external components required
  • No set up or configuration needed
  • No coding of data required
  • 20kbit/s data rate
  • 2 channels
  • Wide supply range
  • Very low power consumption
  • Standby mode
  • operates from a single +3 - 5V DC supply
$26.05 USD from Oatley Electronics
Thanks gramo. That looks like a good deal.
Nigel, All I am doing is trying to connect an I2C master and an I2C slave. I have two parts that are I2C and I cannot change them, but would like to connect them over wireless.
That's just what you told us before, it's of no use - we need to know EXACTLY what you're wanting to do, and not how you think it needs doing.
