windmill charge controller help
I have built a diy charge controller from the schematic attached and it will not charge the battery. I have it connected to a 12v supply and when I short the header (instead of adding buttons) to force it to charge it only turns the dump led off and not the mosfet and it doesn't turn the charge led on.
Any ideas?
Damian
Hi Damian,
Go to the RE Projects Forum and take a look at the schematic I put up for a charge controller/diverter. The one I made several years ago is still going strong on my 24 volt array in the shed and it takes care of 650 watts of PV and a wind generator.
Cheers Bryan
I haven't built this circuit, but may I suggest connecting the relay coil from the MOSFET to the main power source. The DUMP feature should drain the battery, not inject it with an electrical surge.
The dump feature connects the windmill to a load other than the battery so that it doesn't spin out of control and self destruct. It doesn't inject it with a surge of power it merely disconnects the battery to prevent over charging.
I have fixed the problem in the original post and the unit is now working fine and has been for a month or two now. There were a number of problems, a solder bridge on one of the trimpots and i had a p channel fet instead of a n channel and i had missed out a track cut.
see https://www.thebackshed.com/Windmill/forum1/forum_posts.asp?TID=2925&KW=terrapinlogo&PN=0&TPN=1 for the whole story
I would be incline to move fuse F1 to battery leg on other side of relay as the result of it blowing could be a windmill run away where it is presently at. No fuse in line to load dump.
Modify circuit so detection of blown fuse on battery line automatically moves to load dump.
I think I posted on the wrong thread.
Can the OP remember to reduce the pic size when uploading . It took me 30 secs to download and I did not look at any others .I dont have that sort of capacity
The schematic is only about 80kb but the images are large so as others can see the tracks in detail and possibly spot any shorts or errors. I admit they arent small for dialup or poor internet connections but most people have a reasonable connection nowdays so i just uploaded the originals
Hi Damian,
Cheers Bryan
Hey bryan where exactly is this ? could you post a link . I have not been able to find it
