Which IR Remote is very cheap and common?
blueroomelectronics
Looking for an IR Remote to include with my PIC kits that support IR. Velleman make an 2 channel IR remote for about $15 but I know you can get cheap universal remotes with dozens of buttons for about $7.
Looking for...
  • I would like the least expensive remote that you've seen commonly available in your area.
  • Supports Philipls RC5 protocol
  • A 5 button joystick type area (Up,Dn,L,R,enter) would be nice
  • Number pad
  • Not too many buttons
  • Smaller the better
I was thinking of including it with the Mongoose (Robot), Junebug (PIC Lab) as a bundle, maybe a T shirt & screwdriver thrown in for good measure.
*The IR sensor on the Junebug is 38KHz and with a simple cable you could use the 18F1320 on Junebug to control the 18F2525 on the Mongoose (TTL level serial wired)
RC5 uses a 36K carrier. Will that actually work with your 38K receiver?
If it does, then I suggest you consider RC6 which is the protocol that MS MCE uses. There are tons of those remotes on ebay - there must be a volume source. Other than small, those remotes meet all your other needs,
