What would you do with these?
Tipsy
I'm looking for ideas, suggestions and advise...
I bought a job lot from a reclaim broker and among the items are two units which look new and unused. They are made by CODAN and appear to be some sort of power supplies for Satellite broadcast equipment. One I've indentifed as a 6850 BUC, an AC to DC converter apparently...
https://www.electro-tech-online.com/custompdfs/2010/02/BUCPSUs_data.pdf
The other is a SSPA Hub-mount, whatever that is. I can't udentify it in their brochures. It is marked SSPA HUB MOUNT 120W C-BAND W/G OUTPUT BAND 2 and is vented either side due to the cooling fans it requires.
Ideally, I'd like to sell them on to their intended market but I find it hard to imagine I'd find a buyer for this specialist equipment (but if I did, they'd be getting a real bargain!)
So what would you do with them?
Satellite Communications equipment.
Look here:
The thing you can't identify is a 6Ghz 120watt amplifier by the look of it.
But what to do with it?
Advertise it on Ebay?
B I I K !
They are very old uplink Tx amp for C band. Used to be used by TV feed uplinks, like football games. Most have converted to Ku band use although football uplinks still sometimes use C band to avoid possible rain outage common to Ku feeds.
Yes, it does appear to be the 6GHz 120W jobbie.
Perhaps I can start my own pirate satellite station then? :D
I would have thought there'd be some suggestions from the experts - what about if I hacked the PSU or even broke it for "spares" (not that I'm keen to break what is obviously a good condition and presumably fully working unit)? I assume there's some expensive or heavy duty components/circuitry inside.
For instance, could I use the PSU as an AC/DC convertor for household use - test equipment, LED lighting, portable applications etc?
